I don't have much knowledge to rectify this problem so please help.
Thanks in advance.
NFC Communication with the Solutions Cubed, LLC BM019
and an Arduino Uno. The BM019 is a module that
carries ST Micro's CR95HF, a serial to NFC converter.
Wiring:
Nodemcu BM019
IRQ: Pin 5 DIN: pin 2
SS: pin 15 SS: pin 3
MOSI: pin 13 MOSI: pin 5
MISO: pin 12 MISO: pin4
SCK: pin 14 SCK: pin 6
// the sensor communicates using SPI, so include the library:
#include <SPI.h>
const int SSPin = 15; // Slave Select pin
const int IRQPin = 5; // Sends wake-up pulse
byte TXBuffer[40]; // transmit buffer
byte RXBuffer[40]; // receive buffer
byte NFCReady = 0; // used to track NFC state
pinMode(IRQPin, OUTPUT);
digitalWrite(IRQPin, HIGH); // Wake up pulse
pinMode(SSPin, OUTPUT);
digitalWrite(SSPin, HIGH);
Serial.begin(9600);
Serial.println("Started");
SPI.begin();
SPI.setDataMode(SPI_MODE0);
SPI.setBitOrder(MSBFIRST);
SPI.setClockDivider(SPI_CLOCK_DIV32);
// The CR95HF requires a wakeup pulse on its IRQ_IN pin
// before it will select UART or SPI mode. The IRQ_IN pin
// is also the UART RX pin for DIN on the BM019 board.
delay(10); // send a wake up
digitalWrite(IRQPin, LOW); // pulse to put the
delayMicroseconds(100); // BM019 into SPI
digitalWrite(IRQPin, HIGH); // mode
delay(10);
/* IDN_Command identifies the CR95HF connected to the Arduino.
This requires three steps.
1. send command
2. poll to see if CR95HF has data
3. read the response
If the correct response is received the serial monitor is used
to display the CR95HF ID number and CRC code. This rountine is
not that useful in using the NFC functions, but is a good way to
verify connections to the CR95HF.
void IDN_Command()
byte i = 0;
// step 1 send the command
digitalWrite(SSPin, LOW);
SPI.transfer(0); // SPI control byte to send command to CR95HF
SPI.transfer(1); // IDN command
SPI.transfer(0); // length of data that follows is 0
delay(1);
// step 2, poll for data ready
// data is ready when a read byte
// has bit 3 set (ex: B'0000 1000')
while(RXBuffer[0] != 8)
RXBuffer[0] = SPI.transfer(0x03); // Write 3 until
RXBuffer[0] = RXBuffer[0] & 0x08; // bit 3 is set
delay(1);
// step 3, read the data
SPI.transfer(0x02); // SPI control byte for read
RXBuffer[0] = SPI.transfer(0); // response code
RXBuffer[1] = SPI.transfer(0); // length of data
for (i=0;i<RXBuffer[1];i++)
RXBuffer[i+2]=SPI.transfer(0); // data
delay(1);
if ((RXBuffer[0] == 0) & (RXBuffer[1] == 15))
Serial.println("IDN COMMAND-"); //
Serial.print("RESPONSE CODE: ");
Serial.print(RXBuffer[0]);
Serial.print(" LENGTH: ");
Serial.println(RXBuffer[1]);
Serial.print("DEVICE ID: ");
for(i=2;i<(RXBuffer[1]);i++)
Serial.print(RXBuffer[i],HEX);
Serial.print(" ");
Serial.println(" ");
Serial.print("ROM CRC: ");
Serial.print(RXBuffer[RXBuffer[1]],HEX);
Serial.print(RXBuffer[RXBuffer[1]+1],HEX);
else
Serial.println("BAD RESPONSE TO IDN COMMAND!");
/* SetProtocol_Command programs the CR95HF for
ISO/IEC 15693 operation.
1. send command
to display successful programming.
void SetProtocol_Command()
byte i = 0;
SPI.transfer(0x00); // SPI control byte to send command to CR95HF
SPI.transfer(0x02); // Set protocol command
SPI.transfer(0x02); // length of data to follow
SPI.transfer(0x01); // code for ISO/IEC 15693
SPI.transfer(0x0D); // Wait for SOF, 10% modulation, append CRC
delay(1);
delay(1);
if ((RXBuffer[0] == 0) & (RXBuffer[1] == 0))
Serial.println("PROTOCOL SET-"); //
NFCReady = 1; // NFC is ready
else
Serial.println("BAD RESPONSE TO SET PROTOCOL");
NFCReady = 0; // NFC not ready
/* Inventory_Command chekcs to see if an RF
tag is in range of the BM019.
1. send command
to display the the RF tag's universal ID.
void Inventory_Command()
byte i = 0;
SPI.transfer(0x04); // Send Receive CR95HF command
SPI.transfer(0x03); // length of data that follows is 0
SPI.transfer(0x26); // request Flags byte
SPI.transfer(0x01); // Inventory Command for ISO/IEC 15693
SPI.transfer(0x00); // mask length for inventory command
delay(1);
delay(1);
delay(1);
if (RXBuffer[0] == 128)
Serial.println("TAG DETECTED");
Serial.print("UID: ");
for(i=11;i>=4;i--)
Serial.print(" ");
else
Serial.print("NO TAG IN RANGE - ");
Serial.println(RXBuffer[0],HEX);
if(NFCReady == 0)
IDN_Command(); // reads the CR95HF ID
delay(1000);
SetProtocol_Command(); // ISO 15693 settings
delay(1000);
else
Inventory_Command();
delay(10);
