By FlyingHacker
#20607 I have my Arduino IDE setup with the github JSON file for the ESP boards. All is working well.
I was just curious how updates are handled. Is that automatic? I did not see a way to have the IDE check for updates.
Are there nightly builds for the Windows Arduino IDE? Or do I need to build it myself?
What is the procedure for updating?
By tytower
#20617 As I understand it in Preferences You put the Json address as you have done . I think it goes there on startup and checks for a revision. If there is one it is downloaded and placed in the packages .
Click on the link at the bottom of preferences.txt (It does not look like a link) and it will take you to where those packages are on your machine. select ESP8266 /hardware and you will see if there are any added .
1.6.4-673-g8cd3697 on 29/5/15 is the latest I think
By FlyingHacker
#20632 OK. Thanks for the update. I had found those files, and they are at the version you indicated.
When there is an update are the old versions saved? Or will it overwrite everything in that folder?
I have applied a couple of modifications.
