Can you post your sketch may be it'll be helpful ?
Explore... Chat... Share...
#include <WiFiClient.h>
#include <ESP8266WebServer.h>
const int PIN_INPUT = 2;
const int PIN_OUTPUT = 0;
const char* ssid = "my_ssid";
const char* password = "my_pass";
int input_prev;
int input_curr;
int output;
ESP8266WebServer server(80);
void do_on() {
Serial.println("OUTPUT: on");
digitalWrite(PIN_OUTPUT, HIGH);
output = HIGH;
void do_off() {
Serial.println("OUTPUT: off");
digitalWrite(PIN_OUTPUT, LOW);
output = LOW;
void do_get() {
if (output)
server.send(200, "text/plain", "ON");
server.send(200, "text/plain", "OFF");
void handle_root() {
Serial.println("HTTP : root");
server.send(200, "text/plain", "Hello from the ESP8266!");
void handle_on() {
Serial.println("HTTP : on");
do_on();
do_get();
void handle_off() {
Serial.println("HTTP : off");
do_off();
do_get();
void handle_get() {
Serial.println("HTTP : get");
do_get();
void setup(void)
Serial.println("\n\rStarting...");
pinMode(PIN_OUTPUT, OUTPUT);
pinMode(PIN_INPUT, INPUT);
input_prev = digitalRead(PIN_INPUT);
Serial.print("Current status: ");
Serial.println(input_prev);
if (input_prev) {
do_on();
} else {
do_off();
server.on("/", handle_root);
server.on("/on", handle_on);
server.on("/off", handle_off);
server.on("/get", handle_get);
server.begin();
void loop(void)
if(WiFi.status() != WL_CONNECTED) {
Serial.print("Trying to connect");
WiFi.begin(ssid, password);
for (int i = 0; i < 10 && WiFi.status() != WL_CONNECTED; i++) {
Serial.print(".");
Serial.print("\n\r");
if(WiFi.status() == WL_CONNECTED) {
Serial.print("Connected to : ");
Serial.println(ssid);
Serial.print("IP address : ");
server.handleClient();
input_curr = digitalRead(PIN_INPUT);
if (input_curr != input_prev) {
if (input_curr) {
Serial.println("INPUT : on");
do_on();
} else {
Serial.println("INPUT : off");
do_off();
input_prev = input_curr;
delay(250);
