inagy wrote:Also, how stable is 0.9.9.2 by you? For me the module reboots randomly. I don't understand because with the factory firmware it was okay. I'm using the Uno to power the board like i did it before, i don't think it's a power issue.
I've noticed that 0.9.9.2 will restart a lot when it receives bad commands. Instead of getting stuck in a busy state like would happen in previous firmwares.
Probably because they've added a watchdog option now...
Support watchdog, auto restart when program have errors occurred, AT command: turn on watchdog AT+CSYSWDTENABLE; turn off watchgod: AT+CSYSWDTDISABLE
Try turning off the watchdog to see if it helps.
Though if the watchdog is causing a restart, I think something wrong is happening (commands are being sent to quickly, etc)
