Anyway, here is the updated code:
// A PIR sensor that sends status to web server. Compiled on Arduino IDE 1.6.4 and written for ESP8266 (ESP-01)
// based upon:
// PIR sensor tester by Limor Fried of Adafruit and the published work of Andy Reischle (AReResearch)
#include "ESP8266WiFi.h"
const char* ssid = "MommaBug";
const char* password = "u*****************7";
const char* SensorID = "2";
int inputPin = 2; // GPIO2 is pin 2 on Arduino, pin 4 on NodeMCU
int pirState = 0; // we start, assuming no motion detected
int val = 0; // variable for reading the pin status
pinMode(inputPin, INPUT); // declare sensor as input
Serial.begin(9600);
//Connect to AP
Serial.println(ssid);
WiFi.begin(ssid, password);
delay(15000);
Serial.print(".");
Serial.println("");
void loop(){
val = digitalRead(inputPin); // read input value
if (val == 1) { // check if the input is 1
delay(150);
if (pirState == 0) {
// we have just turned on
Serial.println("Motion detected!");
SendAlarm();
// We only want to print on the output change, not state
pirState = 1;
} else {
delay(300);
if (pirState == 1){
// we have just turned off
Serial.println("Motion ended!");
SendClear();
pirState = LOW;
// Send alarm to Fred
void SendAlarm()
WiFiClient client;
String url = ("http://172.16.0.1/alarm.php?SensorID=2&status=ALARM"); //This one is hardcoded to print URL, you can change it to anything really, it wont affect the actual operation
Serial.print("Sending web message to: ");
Serial.println(url);
if
(client.connect("172.16.0.1", 80));
client.println("GET /alarm.php?SensorID=2&status=ALARM" "HTTP/1.1\r\n");//This one is hardcoded to send an ALARM status
client.println("Host: MOMMABUG.HOME\r/n");
client.println("Accept: */*\r\n");
client.print("User-Agent: Mozilla/4.0 (compatible; esp8266 Lua; Windows NT 5.1)\r\n");//I kept the LUA reference on the header, might not make any difference....
client.println("\r\n");
if (client.connected()) {
client.stop();
// Send clear to Fred
void SendClear()
String clr = ("http://172.16.0.1/alarm.php?SensorID=2&status=CLEAR");
WiFiClient client;
Serial.println(clr);
if
client.println("GET /alarm.php?SensorID=2&status=CLEAR" "HTTP/1.1\r\n");
client.stop();
