certeza wrote:By the way, the main reason I use the attiny is to prevent resetting the esp-12 when it has not finished its task. That can happen if you connect the pir directly to the esp-12.
During the time you work on something, you take down the trigger interrupt. And when you are finished, you set the interrupt up again. Or there's some other reasons, it's not possible?
