By sohialsadiq
#26631
sohialsadiq wrote:
sohialsadiq wrote:
kolban wrote:Howdy my friend, I don't think you have given nearly enough information to allow the community to assist you. What is the nature of the problem that you are seeing? What does your code look like? What do you "see" when you attempt?
Neil
Hello Neil,
i am just a beginner in nodemcu using 12E model, few days ago it was working fine it
but when i install arduino IDE again it upload all sketch on 0X0000000
when i upload sketch this happen
Global variables use 48,696 bytes (59%) of dynamic memory, leaving 33,224 bytes for local variables. Maximum is 81,920 bytes.
Uploading 304864 bytes from C:\Users\SOHAIL~1\AppData\Local\Temp\build5585173374228934113.tmp/WiFi_AP_java4.cpp.bin to flash at 0x00000000
i don't know what is wrong.
Sketch uses 300,716 bytes (28%) of program storage space. Maximum is 1,044,464 bytes.
Before i reinstall arduino ide it up load like this
Uploading 31808 bytes from C:\Users\SOHAIL~1\AppData\Local\Temp\build5270599839070223226.tmp/DHTtester.cpp_00000.bin to flash at 0x00000000
Uploading 172744 bytes from C:\Users\SOHAIL~1\AppData\Local\Temp\build5270599839070223226.tmp/DHTtester.cpp_10000.bin to flash at 0x00010000
By sohialsadiq
#26672
martinayotte wrote:Yes, in the older days of ArduinoIDE, it was uploading sketches in 2 binaries, but now it is done with a single one.
This is not a issue, it is an enhancement ...
Thanks, i clear it i was thinking may be something wrong!
