By DaveEvans
#59506
katz wrote: It only crashes when there are multiple browsers accessing the ESP at the same time.
If you have any ideas...to solve the multiple-access-crashing problem, please leave a message here. Thanks, Peter.
Has anyone found a solution to this problem?
By pulsar123
#61243 Hello,
My first post here. I stumbled across this thread while trying to figure out how to program my ESP8266 so it would serve as a dynamic web server for the data collected by Arduino Nano, and also would relay a couple of simple commands (buttons pressed) from the browser to Arduino. (This will be used as a security and monitoring device for my 3D printer: http://pulsar124.wikia.com/wiki/3D_Guardian). I know C++/Arduino, but unfortunately know almost nothing about web programming (Javascript, XML etc).
The OP's code in the first post here seems like a good start; I managed to run it on my ESP8266, and by making this simple modification to the function buildXML() I can now read serial data (e.g. from my Arduino) and pass it on to javascript:
Code: Select allvoid buildXML() {
  String content = "";
  char character;
  while (Serial.available()) {
    character = Serial.read();
    content.concat(character);
  XML = "<?xml version='1.0'?>";
  XML += "<response>";
  //  XML+=millis2time();
  XML += content.substring(0,3);
  XML += "</response>";
Now the stuff fed to the serial port of the ESP is dynamically displayed in the browser.
But I need to display multiple numbers received from Arduino, and can't figure out how to expand the OP's code to have that functionality. I tried to add another section to buildXML(),
Code: Select all  XML += "<response2>";
  XML += content.substring(3,6);
  XML += "</response2>";
and duplicated the three relevant lines in buildJavascript():
Code: Select all  javaScript += "function handleServerResponse(){\n";
  javaScript += " if(xmlHttp.readyState==4 && xmlHttp.status==200){\n";
  javaScript += "   xmlResponse=xmlHttp.responseXML;\n";
  javaScript += "   xmldoc = xmlResponse.getElementsByTagName('response');\n";
  javaScript += "   message = xmldoc[0].firstChild.nodeValue;\n";
  javaScript += "   document.getElementById('param1').innerHTML=message;\n";
  javaScript += "   xmldoc = xmlResponse.getElementsByTagName('response2');\n";
  javaScript += "   document.getElementById('param2').innerHTML=message;\n";
(the new lines are the three lines at the bottom). Finally, I added one more line to buildWebsite():
Code: Select allvoid buildWebsite() {
  buildJavascript();
  webSite = "<!DOCTYPE HTML>\n";
  webSite += javaScript;
  webSite += "<BODY onload='process()'>\n";
  webSite += "<BR>3D Printer control<BR>\n";
  webSite += "Param1 = <A id='param1'></A><BR>\n";
  webSite += "Param2 = <A id='param2'></A>\n";  // The new line
  webSite += "</BODY>\n";
  webSite += "</HTML>\n";
Unfortunately, this doesn't work: once I add the <response2> stuff to buildXML(), the script no longer works: param1 and param2 fields remain empty in the browser when I send a string to the serial port.
I am sure I am doing something stupid here - could anyone please land me a hand?
Also - is there a simple way to add a couple of buttons to the web script, so I could send commands to Arduino?
Thanks a lot for any help!
