I am just starting with ESP8266, but I did quite some arduino projects in the past. Therefore I decided to go with the Arduino library for the ESP8266. I have bought some ESP-12 modules and wireed them up on a breadboard.
I currently try to switch GPIO pins from my webbrowser. The ESP is connected to my home router AP. The esp hosts a rudimentary HTTP website.
Essentially I use the WiFiWebServer example without modification.
My problem is that even though I tell the ESP to connect to my existing wifi AP, the ESP itself also starts in SoftAP mode. This in itself would not be totally bad, but it also interferes with the GPIO pins behaviour. When I try to connect to the ESP SoftAP the GPIO pins go low for a really short break a couple times. (The LED hooked up to GPIO2 blinks a couple times, although I expect it to light up steadily)
Unfortunately it seems I can not find any documentation which tells me how to actively disable the SoftAP mode. Only how to activate it. But it is active without me putting code to activate it.
How do I fix this behaviour ?
