I've been playing with the ESP the last week (No prior coding experience at all, skills mainly consist of copy / paste, trying to figure things out as I go!)
I have the following code (kindly copied from an instructables project):
#include <SoftwareSerial.h>
#include <DHT.h>
#define DEBUG
#define _ledpin 13
//*-- Hardware Serial
#define _baudrate 9600
//*-- Software Serial
#define _rxpin 2
#define _txpin 3
SoftwareSerial debug( _rxpin, _txpin ); // RX, TX
//*-- DHT11
#define _dhtpin 8
#define _dhttype DHT11
DHT dht11( _dhtpin, _dhttype );
uint8_t dhtbuf[2];
//*-- IoT Information
#define SSID "SSID"
#define PASS "PASSWORD"
#define IP "184.106.153.149" // ThingSpeak IP Address: 184.106.153.149
//*-- Build GET Command
// GET /update?key=[THINGSPEAK_KEY]&field1=[data 1]&filed2=[data 2]...;
String GET = "GET /update?key=MYKEYHERE";
Serial.begin( _baudrate );
debug.begin( _baudrate );
sendDebug("AT");
delay(5000);
if(Serial.find("OK"))
debug.println("ESP8266 CONNECTED\nREADY TO SEND DATA");
connectWiFi();
// Start DHT11 Sensors
dht11.begin();
pinMode( _ledpin, OUTPUT );
digitalWrite( _ledpin, LOW );
dhtbuf[0] = dht11.readHumidity();
dhtbuf[1] = dht11.readTemperature();
// DHT11 Section
if( isnan(dhtbuf[0]) || isnan(dhtbuf[1]) )
debug.println( "FAILED TO READ FROM DHT SENSOR" );
digitalWrite( _ledpin, HIGH );
char buf[3];
String HH, TT;
buf[0] = 0x30 + dhtbuf[1] / 10;
buf[1] = 0x30 + dhtbuf[1] % 10;
TT = (String(buf)).substring( 0, 2 );
buf[0] = 0x30 + dhtbuf[0] / 10;
buf[1] = 0x30 + dhtbuf[0] % 10;
HH = (String(buf)).substring( 0, 2 );
updateDHT11( TT, HH );
#ifdef DEBUG
debug.print("Humidity: ");
debug.print( HH );
debug.print(" %\t");
debug.print("Temperature: ");
debug.print( TT );
debug.println(" *C\t");
#endif
delay(60000); // 60 second
void updateDHT11( String T, String H )
// ESP8266 Client
String cmd = "AT+CIPSTART=\"TCP\",\"";
cmd += IP;
cmd += "\",80";
sendDebug(cmd);
delay(2000);
if( Serial.find( "Error" ) )
debug.print( "CANNOT CONNECT\nEXITING" );
return;
cmd = GET + "&field1=" + T + "&field2=" + H +"\r\n";
Serial.print( "AT+CIPSEND=" );
Serial.println( cmd.length() );
if(Serial.find( ">" ) )
debug.print(">");
debug.print(cmd);
Serial.print(cmd);
sendDebug( "AT+CIPCLOSE" );
if( Serial.find("OK") )
debug.println( "DATA SENT" );
debug.println( "DATA NOT SENT\nEXITING" );
void sendDebug(String cmd)
debug.print("SEND: ");
debug.println(cmd);
Serial.println(cmd);
boolean connectWiFi()
Serial.println("AT+CWMODE=1");
delay(2000);
String cmd="AT+CWJAP=\"";
cmd+=SSID;
cmd+="\",\"";
cmd+=PASS;
cmd+="\"";
sendDebug(cmd);
delay(5000);
debug.println("WIFI CONNECTED");
return true;
debug.println("ERROR CONNECTING TO WIFI");
return false;
cmd = "AT+CIPMUX=0";
sendDebug( cmd );
if( Serial.find( "Error") )
debug.print( "CANNOT SET SINGLE CONNECTION MODE" );
return false;
It seems that first time around the ESP fails to send the data... I receive the following in the debug terminal:
SEND: AT
ESP8266 CONNECTED
READY TO SEND DATA
SEND: AT+CWJAP="SSID","PASSWORD"
WIFI CONNECTED
SEND: AT+CIPSTART="TCP","184.106.153.149",80
SEND: AT+CIPCLOSE
DATA NOT SENT
EXITING
Humidity: 56 %.Temperature: 22 *C.
After the 1st loop it seems to be connected fine and continues along indefinitely with no more errors.
To try and figure out why I connected the ESP directly to my terminal and tried issuing the commands:
AT+CIPSEND=54
GET /update?key=MYKEYHERE&field1=23&field2=56
It worked fine without errors the first time around...
Can anyone help me understand why my program seems to have issues first time around? I've literally been trying to figure it out for a week!
I feel the grey hairs coming
