By l0ur3nz0
#8320 I also have a pro micro (sparkfun, wich is an leonardo in other form factor, I think) but couldn't connect with ESP... could you please post some code, wiring and mods (HW, SW, if any) and also wich IDE did you use?
I have no clue why I cant communicate... with USB-to-TTL adapter ESP modules work fine. both externally powered, with and without 5v-3,3v level conversion.
By Sandbird
#41099
l0ur3nz0 wrote:I also have a pro micro (sparkfun, wich is an leonardo in other form factor, I think) but couldn't connect with ESP... could you please post some code, wiring and mods (HW, SW, if any) and also wich IDE did you use?
Did you ever find the solution to this problem, because i am also facing the same thing....I have a pro micro and no mater what i've tried, it just wont connect with the esp. Like you ttl works fine though.
