I am searching a few days how can I display an int value on my webpage, storing in the SPIFFS.
I am not a programmer knowing some #C code.
I use the ESP8266 Nodemcu with arduino IDE software, intsall the last stable library from the list.
The library I using ESP8266WebServer.h, all my HTML, CSS files are store in the SPIFFS.
I found a code that using another library I try to adjust it for my code, but I don;t know how to do that, I am here to learning, receive an explain for code, the most important thing is to succeed what I want to do with your help
my ESP arduino IDE code
#include <WiFiClient.h>
#include <ESP8266WebServer.h>
#include <ESP8266mDNS.h>
#include <FS.h>
const char* ssid = "****";
const char* password = "****";
const String DISPLAY_DATA_HTML = "/html/display_data.html";
ESP8266WebServer server(80);
int MyValue = 0;Code to display my disply_page.html
void DisplayData()
String form = "";
File f = SPIFFS.open(DISPLAY_DATA_HTML, "r");
if (!f){
Serial.println("Can't open update html file");
server.send(404, "text/html", "File not found");
else{
char buf[1024];
int siz = f.size();
while(siz > 0) {
size_t len = std::min((int)(sizeof(buf) - 1), siz);
f.read((uint8_t *)buf, len);
buf[len] = 0;
form += buf;
siz -= sizeof(buf) - 1;
f.close();
server.send(200, "text/html", form);
}The setup Code
void setup(void){
if (!SPIFFS.begin()) {
Serial.println("Failed to mount file system");
return;
WiFi.begin(ssid, password);
Serial.println("");
// Wait for connection
Serial.print(".");
Serial.println("");
Serial.println(ssid);
Serial.print("IP address: ");
if (MDNS.begin("esp8266")) {
Serial.println("MDNS responder started");
server.on("/display_data",DisplayData);
server.on("/reqEtatVariables", [&](){
server.send(200, "text/XML", String((int)MyValue)); // send to someones browser when asked
server.serveStatic("/css", SPIFFS, "/html/css");
server.serveStatic("/display_data.html", SPIFFS, "/html/display_data.html");
server.begin();
if (!MDNS.begin(host)) {
Serial.println("Error setting up MDNS responder!");
while(1){
delay(1000);
Serial.println("mDNS responder started");
// Add service to MDNS-SD
MDNS.addService("http", "tcp", 80);
}Loop code
void loop(void){
server.handleClient();
MyValue = random(1,1000); // generate random number between 1 & 1000
My HTML file
<!DOCTYPE html>
<html lang="en">
<head>
<meta charset="utf-8" />
<script>
function obtenirVariables()
var uniqueURL = "reqEtatVariables" + "&aleatoire=" + Math.trunc(Math.random() * 1000000);
var request = new XMLHttpRequest();
request.onreadystatechange = function()
if (this.readyState == 4) {
if (this.status == 200) {
if (this.responseXML != null) {
document.getElementById("DataFromEsp").innerHTML =
this.responseXML.getElementsByTagName('send_data')[0].childNodes[0].nodeValue;
request.open("GET", uniqueURL , true);
request.send(null);
setTimeout("obtenirVariables()", 1000);
</script>
<title>Irrigation System for Plants</title>
<link href="css/style.css" rel="stylesheet">
</head>
<body onload="obtenirVariables()">
<header>
<div id="header">
<div id="header-top">
<h2>Welcome to your Irrigation System for Plants</h2>
</div> <!-- close div header-top -->
<div id="header-bottom">
<nav id="menu">
<ul>
<li><a href="/config">Home</a></li>
<li class="selected"><a href="/display_data">Display Data Sensor</a></li>
<li><a href="">jQuery</a></li>
<li><a href="">PHP</a></li>
<li><a href="">System</a></li>
<li><a href="">Design</a></li>
<li><a href="/update">System</a></li>
<div class="current">
<div class="ctoparr"></div>
<div class="cback"></div>
<div class="cbotarr"></div>
</div>
</ul>
</nav>
</div> <!-- close div header-bottom -->
</div> <!-- close div header -->
</header>
<div class="container">
<div class="form-style-10">
<h1>Display Soil Sensors Datas<!-- <span>Sign up and tell us what you think of the site!</span> --></h1>
<div class="section"><span>F</span>Display Soil Sensors Datas of your Plants</div>
<div class="inner-wrap">
<p>My Data is<span id="DataFromEsp">...</span></p>
</div>
</div>
</div> <!-- close div container -->
</body>
</html>Who could help me ?
