Here is the code with out WiFi.
* "Object Placement" Puzzle
* This puzzle requires the player to place one or more items in the
* correct location, at which point an RFID tag embedded in the object
* is detected by a sensor.
* When all sensors read the tag of the correct object, the puzzle is solved.
* Demonstrates:
* - SPI interface shared between several devices
* - RFID library
// DEFINES
// Provides debugging information over serial connection if defined
#define DEBUG
// LIBRARIES
// Standard SPI library comes bundled with the Arduino IDE
#include <SPI.h>
// Download and install from https://github.com/miguelbalboa/rfid
#include <MFRC522.h>
// CONSTANTS
// The number of RFID readers
const byte numReaders = 3;
// Each reader has a unique Slave Select pin SDA
const byte ssPins[] = {15, 4, 2};
// They'll share the same reset pin
const byte resetPin = 5;
// This pin will be driven LOW to release a lock when puzzle is solved
const byte lockPin = 0;
// The sequence of NFC tag IDs required to solve the puzzle
const String correctIDs[] = {"cb675e7b", "947aae1e", "7c25e82b"};
// GLOBALS
// Initialise an array of MFRC522 instances representing each reader
MFRC522 mfrc522[numReaders];
// The tag IDs currently detected by each reader
String currentIDs[numReaders];
* Initialisation
#ifdef DEBUG
// Initialise serial communications channel with the PC
Serial.begin(9600);
Serial.println(F("Serial communication started"));
#endif
// Set the lock pin as output and secure the lock
pinMode(lockPin, OUTPUT);
digitalWrite(lockPin, HIGH);
// Initialise the SPI bus
SPI.begin();
for (uint8_t i=0; i<numReaders; i++) {
// Initialise the reader
mfrc522[i].PCD_Init(ssPins[i], resetPin);
// Set the gain to max - not sure this makes any difference...
// mfrc522[i].PCD_SetAntennaGain(MFRC522::PCD_RxGain::RxGain_max);
#ifdef DEBUG
// Dump some debug information to the serial monitor
Serial.print(F("Reader #"));
Serial.print(i);
Serial.print(F(" initialised on pin "));
Serial.print(String(ssPins[i]));
Serial.print(F(". Antenna strength: "));
Serial.print(mfrc522[i].PCD_GetAntennaGain());
Serial.print(F(". Version : "));
mfrc522[i].PCD_DumpVersionToSerial();
#endif
// Slight delay before activating next reader
delay(200);
#ifdef DEBUG
Serial.println(F("--- END SETUP ---"));
#endif
* Main loop
// Assume that the puzzle has been solved
boolean puzzleSolved = true;
// Assume that the tags have not changed since last reading
boolean changedValue = false;
// Loop through each reader
// Initialise the sensor
mfrc522[i].PCD_Init();
// String to hold the ID detected by each sensor
String readRFID = "";
// If the sensor detects a tag and is able to read it
if(mfrc522[i].PICC_IsNewCardPresent() && mfrc522[i].PICC_ReadCardSerial()) {
// Extract the ID from the tag
readRFID = dump_byte_array(mfrc522[i].uid.uidByte, mfrc522[i].uid.size);
// If the current reading is different from the last known reading
if(readRFID != currentIDs[i]){
// Set the flag to show that the puzzle state has changed
changedValue = true;
// Update the stored value for this sensor
currentIDs[i] = readRFID;
// If the reading fails to match the correct ID for this sensor
if(currentIDs[i] != correctIDs[i]) {
// The puzzle has not been solved
puzzleSolved = false;
// Halt PICC
mfrc522[i].PICC_HaltA();
// Stop encryption on PCD
mfrc522[i].PCD_StopCrypto1();
#ifdef DEBUG
// If the changedValue flag has been set, at least one sensor has changed
if(changedValue){
// Dump to serial the current state of all sensors
Serial.print(String(i));
Serial.print(F(" on Pin #"));
Serial.print(String((ssPins[i])));
Serial.print(F(" detected tag: "));
Serial.println(currentIDs[i]);
Serial.println(F("---"));
#endif
// If the puzzleSolved flag is set, all sensors detected the correct ID
if(puzzleSolved){
onSolve();
// Add a short delay before next polling sensors
//delay(100);
* Called when correct puzzle solution has been entered
void onSolve(){
#ifdef DEBUG
// Print debugging message
Serial.println(F("Puzzle Solved!"));
#endif
// Release the lock
digitalWrite(lockPin, LOW);
while(true) {
delay(1000);
* Helper function to return a string ID from byte array
String dump_byte_array(byte *buffer, byte bufferSize) {
String read_rfid = "";
for (byte i=0; i<bufferSize; i++) {
read_rfid = read_rfid + String(buffer[i], HEX);
return read_rfid;
And here is what I have tried to add to the code to make the WiFi Post Request when the puzzle is solved. I am trying to make the esp8266 send a post command of http://192.168.252.50/control?cmd=GPIO,12,1
* Demonstrates:
* - RFID library
// DEFINES
#define DEBUG
// LIBRARIES
#include <SPI.h>
//WiFi
#include <WiFiClient.h>
// CONSTANTS
const byte ssPins[] = {15, 4, 2}; //THE GPIO PINS on ESP8266
//Static IP address configuration
IPAddress staticIP(192, 168, 252, 61); //ESP static ip
IPAddress gateway(192, 168, 252, 1); //IP Address of your WiFi Router (Gateway)
IPAddress subnet(255, 255, 255, 0); //Subnet mask
IPAddress dns(8, 8, 8, 8); //DNS
//SSID and Password of your WiFi router
const char* ssid = "yourWiFissid"; // These are changed to protect the innocent
const char* password = "yourWiFipassword"; //These are changed to protect the innocent
// GLOBALS
* Initialisation
#ifdef DEBUG
Serial.begin(9600);
#endif
SPI.begin();
// WIFI Connection
WiFi.begin(ssid, password); //Connect to your WiFi router
Serial.println("");
WiFi.config(staticIP, subnet, gateway, dns);
WiFi.mode(WIFI_STA); //WiFi mode station (connect to wifi router only
// Wait for connection
Serial.print(".");
//If connection successful show IP address in serial monitor
Serial.println("");
Serial.println(ssid);
Serial.print("IP address: ");
Serial.println(WiFi.localIP()); //IP address assigned to your ESP
#ifdef DEBUG
Serial.print(i);
#endif
delay(200);
#ifdef DEBUG
#endif
* Main loop
// Halt PICC
#ifdef DEBUG
if(changedValue){
#endif
if(puzzleSolved){
onSolve();
//delay(100);
void onSolve(){
#ifdef DEBUG
#endif
// Release the lock
HTTPClient http; //Declare object of class HTTPClient
http.begin("http://192.168.252.50/control?cmd=GPIO12,1"); //Specify request destination
int httpCode = http.GET();
if (httpCode > 0) { //Check the returning code
String payload = http.getString(); //Get the request response payload
Serial.println(payload); //Print the response payload
http.end(); //Close connection
while(true) {
delay(1000);
return read_rfid;
Any help would be extremely appreciated
