According to the documentation I needed to connect RST and GPIO16. This didn't worked for a long time (few minutes). After reading this forum I found several possible solutions (stated below) but none of them worked.
- 470 ohm resistor between RST en GPIO16. This worked for a few weeks but after a while it stopped working.
- 1K ohm resistor between RST en GPIO16. This worked for a few weeks but after a while it stopped working.
- 1K ohm resistor between RST en GPIO16 and a 10K resistor between VCC and RST (pull up). This doe not seem to work at all.
All three options are not a permanent solution and after a while (sometimes 1 cycle, sometimes for days or weeks) the output is a as shown below and the red LED is dimmed.
Going into deep sleep
rll⸮⸮|⸮l⸮|⸮l⸮b|⸮⸮⸮⸮r⸮bl⸮b⸮⸮nn⸮lnn⸮⸮⸮bp⸮⸮lrlrl⸮r⸮n⸮b⸮nbp⸮Does anyone know how to solve this since it is now unreliable.
