It will NOT compile using board Version 2.5.0
The compiler error points to line 45 in sendemail.cpp library file.
ambiguous overload for 'operator+=' (operand types are 'String' and 'IPAddress')
buffer += client->localIP();
Can someone suggest an edit to sendemail.cpp so that it will work with board Version 2.5.0 ?
Unfortunately the author of the sendemail library, Peter Gorasz, does not include his email on GitHub.
Here is the error text:
Arduino: 1.8.8 (Windows 10), Board: "NodeMCU 1.0 (ESP-12E Module), 80 MHz, Flash, Enabled, 4M (no SPIFFS), v2 Lower Memory, Disabled, None, Only Sketch, 115200"
C:\Utilities\arduino-1.8.8\portable\sketchbook\libraries\esp8266-sendemail-master\sendemail.cpp: In member function 'bool SendEmail::send(const String&, const String&, const String&, const String&)':
C:\Utilities\arduino-1.8.8\portable\sketchbook\libraries\esp8266-sendemail-master\sendemail.cpp:45:10: error: ambiguous overload for 'operator+=' (operand types are 'String' and 'IPAddress')
C:\Utilities\arduino-1.8.8\portable\sketchbook\libraries\esp8266-sendemail-master\sendemail.cpp:45:10: note: candidates are:
In file included from C:\Utilities\arduino-1.8.8\portable\packages\esp8266\hardware\esp8266\2.5.0\cores\esp8266/Arduino.h:261:0,
from C:\Utilities\arduino-1.8.8\portable\packages\esp8266\hardware\esp8266\2.5.0\libraries\ESP8266WiFi\src/WiFiClient.h:25,
from C:\Utilities\arduino-1.8.8\portable\sketchbook\libraries\esp8266-sendemail-master\sendemail.h:6,
from C:\Utilities\arduino-1.8.8\portable\sketchbook\libraries\esp8266-sendemail-master\sendemail.cpp:1:
C:\Utilities\arduino-1.8.8\portable\packages\esp8266\hardware\esp8266\2.5.0\cores\esp8266/WString.h:120:18: note: String& String::operator+=(const char*) <near match>
String & operator +=(const char *cstr) {
C:\Utilities\arduino-1.8.8\portable\packages\esp8266\hardware\esp8266\2.5.0\cores\esp8266/WString.h:120:18: note: no known conversion for argument 1 from 'IPAddress' to 'const char*'
C:\Utilities\arduino-1.8.8\portable\packages\esp8266\hardware\esp8266\2.5.0\cores\esp8266/WString.h:124:18: note: String& String::operator+=(char)
String & operator +=(char c) {
C:\Utilities\arduino-1.8.8\portable\packages\esp8266\hardware\esp8266\2.5.0\cores\esp8266/WString.h:128:18: note: String& String::operator+=(unsigned char)
String & operator +=(unsigned char num) {
C:\Utilities\arduino-1.8.8\portable\packages\esp8266\hardware\esp8266\2.5.0\cores\esp8266/WString.h:132:18: note: String& String::operator+=(int)
String & operator +=(int num) {
C:\Utilities\arduino-1.8.8\portable\packages\esp8266\hardware\esp8266\2.5.0\cores\esp8266/WString.h:136:18: note: String& String::operator+=(unsigned int)
String & operator +=(unsigned int num) {
C:\Utilities\arduino-1.8.8\portable\packages\esp8266\hardware\esp8266\2.5.0\cores\esp8266/WString.h:140:18: note: String& String::operator+=(long int)
String & operator +=(long num) {
C:\Utilities\arduino-1.8.8\portable\packages\esp8266\hardware\esp8266\2.5.0\cores\esp8266/WString.h:144:18: note: String& String::operator+=(long unsigned int)
String & operator +=(unsigned long num) {
C:\Utilities\arduino-1.8.8\portable\packages\esp8266\hardware\esp8266\2.5.0\cores\esp8266/WString.h:148:18: note: String& String::operator+=(float)
String & operator +=(float num) {
C:\Utilities\arduino-1.8.8\portable\packages\esp8266\hardware\esp8266\2.5.0\cores\esp8266/WString.h:152:18: note: String& String::operator+=(double)
String & operator +=(double num) {
C:\Utilities\arduino-1.8.8\portable\packages\esp8266\hardware\esp8266\2.5.0\cores\esp8266/WString.h:156:18: note: String& String::operator+=(const __FlashStringHelper*) <near match>
String & operator += (const __FlashStringHelper *str){
C:\Utilities\arduino-1.8.8\portable\packages\esp8266\hardware\esp8266\2.5.0\cores\esp8266/WString.h:156:18: note: no known conversion for argument 1 from 'IPAddress' to 'const __FlashStringHelper*'
exit status 1
Error compiling for board NodeMCU 1.0 (ESP-12E Module).
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
