e.g. ((FunctionPointer) pgm_read_word (&mainGameLoop[gameState]))();
I have to change that simple one line code to a switch statement which make the code more complex.
Any one with experience using function pointer in ESP8266 as state machine in the Arduino IDE? Any idea to make the function pointer work in ESP8266 ?
Here is the simplified code. The actual code is much more complex and a lot of repeated use of this statement.
typedef void (*FunctionPointer) ();
void stateIntro () {
Serial.println ("Intro");
void stateMenu () {
Serial.println ("Menu");
void statePlay () {
Serial.println( "Play");
const FunctionPointer PROGMEM mainGameLoop[] = {
stateIntro, // 0
stateMenu, // 1
statePlay, // 2
void setup () {
Serial.begin(74880);
Serial.println ("game starated");
byte gameState = 0;
Serial.println (pgm_read_word (&mainGameLoop[gameState]));
Serial.print (gameState);
Serial.print (" ");
// this is the original ATMega32U4 that doe snot work in ESP8266
// I hve to replace with this complex switch statement.
switch (gameState) {
case 0:
stateIntro();
break;
case 1:
stateMenu();
break;
case 2:
statePlay();
break;
if (++ gameState > 2) gameState = 0;
delay (1000);
