By ledfreak3d
#27142 Anybody know whats going on here
no Mather what I do cant get more then 8 leds to respond
#include <NeoPixelBus.h>
#define pixelCount 12
NeoPixelBus strip = NeoPixelBus(pixelCount, 0);  //D10(TX) on the nodemcu board is 1, D2 is pin 4
WiFiServer server(80);
//*-- IoT Information
const char* SSID = "rgbled";
const char* PASS = "123456789";
int redVal;
int redTemp=1;
int greVal;
int bluVal;
int mattradVal;
int input;  // web button input
char colorBuff[4];
unsigned long previousMillis = 0;        // will store last time LED was updated
const long interval = 30;           // interval at which to blink (milliseconds)
int intCyclopsLedCnt=100;
    Serial.begin(115200);  //NOTE:  this must be done after "strip.Begin()" or Serial Monitor will crash the ESP8266
    delay(50);
    Serial.print("starting up and connecting to: ");
    Serial.println(SSID);
    WiFi.softAP(SSID, PASS);  //start the ESP8266 as an Access point
    delay(1000);
    server.begin();  //Start the web server
    strip.Begin();  //this resets all the neopixels to an off state, NOTE: this must be done before serial.begin or "serial monitor" will crash the ESP8266
    strip.Show();
    delay(100);
  int bufLength;
//  strip.SetPixelColor(1,RgbColor(44,55,0));
//  strip.Show();
  if(input==1)
    Test1();
  if(input==2)
   Test2();
  if(input==3)
    Test3();
  WiFiClient client = server.available();    // Check if a client has connected
  if (!client) {
    return;  //do nothing if there is not a client for the server
  Serial.println("new client");
  while(!client.available()){
    delay(1);
  String request = client.readStringUntil('\r');
  Serial.println("Request is:");
  Serial.println(request);
  client.flush();
  if(request.indexOf("submit") != -1) {  //this is used to ignore "favicon.ico" and other requests
     int Pos_r = request.indexOf("redVal");
     int Pos_g = request.indexOf("greVal", Pos_r);  //finds a location of a string "g", after the position of "r"
     int Pos_b = request.indexOf("bluVal", Pos_g);
     int Pos_rad = request.indexOf("matrad",Pos_b);
     int End = request.indexOf("H", Pos_b);
     if(End < 0){
       End =  request.length() + 1;
     //red
     bufLength = ((Pos_g) - (Pos_r+12));    //the 7 is for the "redVal=" string
     if(bufLength > 4){  //dont overflow the buffer  (we only want 3 digits)
       bufLength = 4;
     request.substring((Pos_r+7), (Pos_g-1)).toCharArray(colorBuff, bufLength);  //transfer substring to buffer  (cuts from past the "r=" to just before the "g", stores the length into a buffer)
     redVal = atoi(colorBuff);  //converts the array (3 digits) into an interger, this will be the red value
     //Green
     bufLength = ((Pos_b) - (Pos_g+7));    //the 7 is for the "greVal=" string
       bufLength = 4;
     request.substring((Pos_g+7), (Pos_b-1)).toCharArray(colorBuff, bufLength);  //transfer substring to buffer
     greVal = atoi(colorBuff);
     //blue
     bufLength = ((Pos_rad) - (Pos_b+7));  //start to get the blue value
       bufLength = 4;
     request.substring((Pos_b+7), (Pos_rad-1)).toCharArray(colorBuff, bufLength);  //transfer substring to buffer
     bluVal = atoi(colorBuff);
     bufLength = ((End) - (Pos_rad+7));
       bufLength = 4;
     request.substring((Pos_rad+7), (End-1)).toCharArray(colorBuff, bufLength);  //transfer substring to buffer
     mattradVal = atoi(colorBuff);
    Serial.println("Red is:  ");
    Serial.println(redVal);
    redTemp=redVal;
    Serial.println("Green is:  ");
    Serial.println(greVal);
    Serial.println("Blue is:  ");
    Serial.println(bluVal);
    Serial.println("radio button is:  ");
//    Serial.println(mattradVal);
     strip.SetPixelColor(0,RgbColor(redVal,greVal,bluVal));
     strip.SetPixelColor(1,RgbColor(redVal,greVal,bluVal));
     strip.SetPixelColor(2,RgbColor(redVal,greVal,bluVal));
     strip.SetPixelColor(3,RgbColor(redVal,greVal,bluVal));
     strip.SetPixelColor(4,RgbColor(redVal,greVal,bluVal));
     strip.SetPixelColor(5,RgbColor(redVal,greVal,bluVal));
     strip.SetPixelColor(6,RgbColor(redVal,greVal,bluVal));
     strip.SetPixelColor(7,RgbColor(redVal,greVal,bluVal));
     strip.Show();
  // Return the response
  client.println("HTTP/1.1 200 OK\r\nContent-Type: text/html\r\n\r\n");
  client.println("<!DOCTYPE HTML>\r\n<html>\r\n<head>\r\n<title>Matt's test page</title>");
  client.println("<meta name='viewport' content='width=device-width', initial-scale='1'>");
  client.println("<br>");
  client.println("<body><center>Set the color and then choose an animation:");
// client.println("<form method=get><br>Red:  <input type='range' min='1' max='100' name=redVal value=redTemp oninput='showValue(this.value)'>");    //was onchange event
  client.println("<span id='range'>0</span>");
  client.println("<script type='text/javascript'>\r\nfunction showValue(newValue)\r\n{\r\ndocument.getElementById('range').innerHTML=newValue;\r\n}\r\n</script>\r\n");
  client.println("<script type='text/javascript'>");
  client.println("function showValue(newValue)");
  client.println("{");
  client.println("document.getElementById('range').innerHTML=newValue;");
  client.println("}");
  client.println("</script>");
//first slider
      client.print("<form method=get><br>Red:  <input type='range' min='0' max='255' value='0' name=redVal value=redTemp oninput='showValue(this.value)'>");
      //second slider
      client.print("<br><br>Green:  <input type='range' min='0' max='255' value='0'name=greVal value=greTemp oninput='showValue1(this.value)'>");
      client.println("<span id='range1'>0</span>");
      client.println("<script type='text/javascript'>\r\nfunction showValue1(newValue)\r\n{\r\ndocument.getElementById('range1').innerHTML=newValue;\r\n}\r\n</script>\r\n");
      //third slider
      client.print("<br><br>Blue:  <input type='range' min='0' max='255' value='0' name=bluVal value=bluTemp oninput='showValue2(this.value)'>");
      client.println("<span id='range2'>0</span>");
      client.println("<script type='text/javascript'>\r\nfunction showValue2(newValue)\r\n{\r\ndocument.getElementById('range2').innerHTML=newValue;\r\n}\r\n</script>\r\n");
  client.print("<br><br><input type=radio name='matrad' value='5' checked>Test1</>");
  client.print("<input type=radio name='input' value='2'>Test2</>");
  client.print("<input type=radio name='input' value='3'>Test3</>");
  client.print("<input type=radio name='input' value='4'>Test4</>");
  client.println("&nbsp;<br><br><input name=H type=submit value=submit><br><br>");  //</form>
  client.println("</form>");
  client.println("<script type='text/javascript'></script>\r\n");
  client.println("</center>");
  client.println("</BODY>");
  client.println("</HTML>");
  delay(1);
  Serial.println("Client disconnected");
  Serial.println("");
void Test1(void)
     strip.SetPixelColor(0,RgbColor(255,30,30));
     strip.SetPixelColor(1,RgbColor(255,30,30));
    strip.Show();
void Test2(void)
  if(currentMillis - previousMillis >= interval)
    // save the last time you blinked the LED
    intCyclopsLedCnt=intCyclopsLedCnt+1;  //advance to the next LED
    if(intCyclopsLedCnt>15)  //There are 8, RGB LED's, this cycles through the 8 going one direction and then 8 going the other direction
      intCyclopsLedCnt=0; //start the LED cyclops over again
    if(intCyclopsLedCnt <= 7)  //are we going from left to right in lighting up the LED's?
      strip.SetPixelColor(intCyclopsLedCnt,RgbColor(redVal,greVal,bluVal));   //turn on the current LED, based on the 3 slider color
      if(intCyclopsLedCnt>0)  //make sure we haave advanced by one LED before we turn off the previous LED
        strip.SetPixelColor(intCyclopsLedCnt-1,RgbColor(0,0,0));   //turn off the previous LED
    if(intCyclopsLedCnt > 7)  //are we advancing from right to left?
      strip.SetPixelColor(15-intCyclopsLedCnt,RgbColor(100,10,10));   //when going in this direction, always be red
      strip.SetPixelColor(16-intCyclopsLedCnt,RgbColor(0,0,0));   //turn off the previous LED
    strip.Show();  //update the neopixels (WS2812 RGB LED's)
void Test3(void)
 Serial.print("test3");
By Barnabybear
#27157
Code: Select all    Serial.println("radio button is:  ");
     strip.Show();
Only a quick read through, but it looks like you only send values to 8 leds.
By ledfreak3d
#27158 Yep already found it but there must be a beter way of doing this for every led
     strip.Show();
By Barnabybear
#27160
ledfreak3d wrote:Yep already found it but there must be a beter way of doing this for every led
     strip.Show();
Yes, you would have thought a "whlie" would have been better - but there might a good reason why not.
