By Labspace
#34422 Modified the code as shown below
Code: Select all#include <SoftwareSerial.h>
SoftwareSerial serial(2,3);
void setup()
 serial.begin(115200);
 serial.println("AT\r\n");
 if(serial.available() >0)
    Serial.println(serial.read());
    Serial.println("Nothing in serial buffer.");
void loop()
It returns "Nothing in serial buffer." . The ESP still responds to AT commands from Serial montior.
By Venkatesh
#34433 "if" is not "loop", you are still reading a single char.
1) First check the AT firmware version and its baud rate
2) Check connection and set correct pins in SoftwareSerial (2 -> RX and 3->TX of esp8266)
3) Use this in setup() after sending command
4) Isn't Serial and serial confusing. For soft serial, use like espSerial.
Code: Select allString response = "";
while (softSerial.available())
   char c = softSerial.read();
   response += c;
Serial.println(response);
