- Tue Feb 02, 2016 1:54 am
#40231
Here's more detail I just wrote:
I saw this post, which got me interested in setting-up my Eclipse IDE with Arduino SDK :
http://hackaday.com/2015/12/12/squash-y ... p-gdbstub/1. Download Espressif's gdbstub :
https://github.com/espressif/esp-gdbstub2. Compiler/assembler/linker flags:
Change -O and -g flags to include symbolic information:
-ggdb -Og # C/C++ compiler, linker (possibly optional in linker I'm unsure)
-ggdb # assembler (possibly optional here too I'm unsure)
3. Look through gdbstub-cfg.h and decide which of the options you want to enable when compiling, add those defines to the compiler
flags to enable the options when compiling, I used:
-DGDBSTUB_REDIRECT_CONSOLE_OUTPUT -DGDBSTUB_CTRLC_BREAK -DGDBSTUB_BREAK_ON_INIT
These options do the following:
GDBSTUB_REDIRECT_CONSOLE_OUTPUT : Allows os_printf to be sent to gdb which will be echod by gdb on-screen without interference.
This works well when using command-line gdb, however when using Eclipse it would not work
I think it broke something internal to Eclipse if I remember rightly.
GDBSTUB_CTRLC_BREAK : Ctrl-c in gdb session will stop esp8266 cpu wherever it is at the time of the Ctrl-c
GDBSTUB_BREAK_ON_INIT : The gdb stub will pause your code within it's init function, thus allowing you time to
attach gdb at your leisure, whereupon you will find your code stopped in the gdb stub
init function, allowing you to set breaks/watches etc and then continue to your main body
of code.
4. Include a call to gdbstub_init() in your setup/init code.
Ensure there are no calls to Serial.begin or anything else that changes the interrupt handler that gdbstub_init will have
attached to.
Ensure the serial UART is initialised before calling gdbstub_init(), by calling uart_div_modify(0, ...), then call gdbstub_init()
e.g. In the case of Arduino-based sdk, modify core_esp8266_main.cpp and place a call to gdbstub_init() immediately after the
call to uart_div_modify(0, ...). In addition I then #ifdef'd out the UART 0 disabling in
core_esp8266_wiring_digital.cpp (function initPins), which would otherwise cancel gdbstub's ability to catch UART interrupts.
5. The version of gdb to use (from command-line or Eclipse IDE) should be xtensa-lx106-elf-gdb or your own locally built
esp8266 sdk version of gdb. Standard (Linux) gdb will not work.
6. Configure gdb settings on gdb startup, I used a command file, with the following:
file ./Debug/esp_gdb.elf
set remotelogfile gdb_rsp_logfile.txt
set remote hardware-breakpoint-limit 1
set remote hardware-watchpoint-limit 1
#set debug remote 1
set debug xtensa 4
set remotebaud 115200
target remote /dev/ttyUSB0
These can by entered manually at the gdb command prompt or put into a file and executed with "gdb -x <commandfile>".
Uncomment the "set debug remote 1" line for additional logging if your gdb session isn't working as you expect, it can
help to solve the problem - it did for me.
7. If using Eclipse IDE with gdb:
a. Create a new debug configuration by creating a new C/C++ Remote Application:
b. "Main" tab:
"C/C++ Application" -- enter the name of the compiled .elf file e.g. "./Debug/esp_gdb.elf"
In order to select the serial port for gdb to use, at the bottom of the main dialog, press "Select Other..."
and select:
"GDB (DSF) Manual Remote Debugging Launcher"
c. "Debugger" tab:
Tick "Stop on startup at", and enter "user_init" ... assuming you are using -DGDBSTUB_BREAK_ON_INIT in compile.
"GDB debugger:" -- Enter the path for the xtensa gdb
c.i. "Connection" sub-tab:
"Type:" dropdown -- select "Serial"
"Device:" -- enter your USB port
"Speed:" -- enter serial speed
8. Start gdb.
If you have used the same gdbstub settings as me, then your code will have stopped at a "break" instruction within
the gdbstub_init function.
If gdb seems to hang, with no prompt then ensure your code has not messed around with the uart and that the gdbstub_init
call is in the right place. gdb hangs in my experience are where it has not received anything back from the serial port
and this is because gdbstub never attached to the uart.
