The list of changes to the first page
Update procedure:
1. Remove the old version.
2. Install the new version DevKit.
ATTENTION!!! When you delete the old version will be removed entire directory C:\Espressif
Explore... Chat... Share...
#ifdef DEVELOP_VERSION
#define NODE_DEBUG
#endif /* DEVELOP_VERSION */
#define NODE_DEBUG
c:/espressif/xtensa-lx106-elf/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld.exe: .output/eagle/debug/image/eagle.app.v6.out section `.irom0.text' will not fit in region `irom0_0_seg'
collect2.exe: error: ld returned 1 exit status
../Makefile:178: recipe for target '.output/eagle/debug/image/eagle.app.v6.out' failed
mingw32-make[1]: *** [.output/eagle/debug/image/eagle.app.v6.out] Error 1
mingw32-make[1]: Leaving directory 'C:/Espressif/examples/nodemcu-firmware/app'
mingw32-make.exe: *** [flash] Error 2
C:/Espressif/examples/nodemcu-firmware/Makefile:111: recipe for target 'flash' failed
picstart wrote:remaining unresolved issuec:/espressif/xtensa-lx106-elf/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld.exe: .output/eagle/debug/image/eagle.app.v6.out section `.irom0.text' will not fit in region `irom0_0_seg'
