Lets get the party started and +1
[url=https://www.banggood.com/custlink/KvGGhGF4wG[/url]
I like ESP8266 and ESP8285 and ESP32
Explore... Chat... Share...
Necromant wrote:Same applies to tcp2uart bridge. If you're running at, say, 9600 and will just send a huge load of bytes over TCP you're likely to get an exception and a reboot. Or your only option is just drop some payload bytes if your buffer overflows.
pvvx wrote:Necromant wrote:Same applies to tcp2uart bridge. If you're running at, say, 9600 and will just send a huge load of bytes over TCP you're likely to get an exception and a reboot. Or your only option is just drop some payload bytes if your buffer overflows.
https://www.youtube.com/watch?v=chDagawOva8
UART tx - Manual update the TCP window (Lwip).
This can be used to throttle data reception (e.g. when received data is programmed to flash and data is received faster than programmed).
UART rx - RTC/CTS.
Do not need to invent new protocols. Do not need to reinvent the wheel... TCP/IP has all the necessary tools.
alonewolfx2 wrote:I wonder one thing. Can we use your tftp update method with other SDK like freertos?
