By cal
#17947 I think I have applied your patch. (I applied it to crosstool-ng in a dirty way and it seems it survived..)
Did improve a little bit:
Some bogus entry vanished from the bt but still I get an endless loop.
Code: Select all(gdb) bt
#0  gdb_breakpoint () at arch_esp8266.c:19
#1  0x402367e0 in nodemcu_init () at user_main.c:225
#2  0x402367e0 in nodemcu_init () at user_main.c:225
#3  0x402367e0 in nodemcu_init () at user_main.c:225
I have to understand more on that ...
Cal
By cal
#17955 You didn't mislead me!
I got a small improvement, you lead me to the code thats responsible and maybe I will understand
the stack stuff ...
BTW: I found out that the function in question is (speaken in java terms) an "method" of the "object"
frame_unwind which has some documentation in its own heder file about the purpose of the "method".
I consider that "documenting the interface" which reduces the need for documenting
the purpose of explicit method implementations for me.
Can you do me a favor?
As far as I understand the OCD/JTAG/whatever stuff the gdb communitates with some JTAG speaking
gdbserver.
Do you have access to the logs of such a communication between gdb and gdb server from the startup to
some single stepping and continue?
I would like to clarify how some gdb stuff is used on a bare metal target.
Thanks in advance and I got the strong feeling there is more gdb communication to come ...
There seem to be only a few people interested in using a debugger to debug. Strange.
Cal
