CHERTS wrote:mariuszb wrote:BMP180 example:
In file i2c_bmp180.c should such a two change (in bold):
bool ICACHE_FLASH_ATTR BMP180_Init()
i2c_init(); // ----------------- should be added here
char temp[80]; //80 bytes buffer is too small for this prints -----------, eg. use 128 bytes
mariuszb you checked i2c_bmp180 example in dealing with real sensor? Can you give an example of a working i2c_bmp180?
Yes, I have BMP180. But its complicated because my program its mixture ESP12,ESP01 with DHT22,BMP180 and DS18B20.
Better just add i2c_init()
and increase this buffer temp[80] to temp[128].
If I find more , I will let You know.
(without init not works on eg. port12 and 13; if buffer is to small..You know what happens )
Ps. Did You read my previous post about httpclient.c - reconect problem???
