Markus Gritsch wrote:Waiting for someone else to upload the mapfile from a build on Linux...
I guess there's very little hope anybody else would do it, especially the same versions of software and SDK built with the same flags...
Explore... Chat... Share...
Lawrence_jeff wrote:Great work, really appreciate the work you do on this.
Any chance we can get the SMING project examples added in? (Manually it plugs right in so should be easily added)
kenn wrote:Lawrence_jeff wrote:Great work, really appreciate the work you do on this.
As you know, you can simply drop the SMING folder into C:\Espressif\ and the SMING projects compile right away. I pull from github right into the SMING directory and I can do this any time I want. Likewise, I can install CHERTS latest stuff over top of my existing C:\Espressif\; it replaces the usual stuff, but leaves the SMING directory just as I left it.
So, to me, there's really no point for CHERTS to include it in his distribution... it's just an extra chore Mikhail would have to do every time he builds...
Markus Gritsch wrote:c:/espressif/xtensa-lx106-elf/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld.exe: .output/eagle/debug/image/eagle.app.v6.out section `.text' will not fit in region `iram1_0_seg'
