By Markus Gritsch
#14769
Kevin Uhlir (N0BEL) wrote:Thanks for responding. For now I've just dropped the math module like others have.
Alternatively, you could also build the integer version using
make EXTRA_CCFLAGS="-DLUA_NUMBER_INTEGRAL"
For me this also works.
However, it would be really cool if CHERTS Windows toolchain could produce the same binaries as the Linux toolchain.
By j0hncc
#14850 I installed this yesterday. It compiles, flashes great.
blinky works. ( using loop: GPIO_OUTPUT_SET(LED_GPIO, state); os_delay_us(DELAY); )
blink2 does not. (using
os_timer_setfn(&blink_timer, (os_timer_func_t *)blink_cb, (void *)0);
os_timer_arm(&blink_timer, DELAY, 1); )
What it does is, lights up the gpio01 led immediately, but never blinks. It's like the timer is not executing the callback or something.
Any Ideas??
This is on a esp-12 module.
Compile output follows. Does this look "OK"?
Code: Select all13:09:04 **** Build of configuration Default for project blinky2 ****
mingw32-make.exe -f C:/Espressif/examples/blinky2/Makefile all
CC user/user_main.c
AR build/app_app.a
LD build/app.out
Section info:
build/app.out:     file format elf32-xtensa-le
Sections:
Idx Name          Size      VMA       LMA       File off  Algn
  0 .data         000009f8  3ffe8000  3ffe8000  000000e0  2**4
                  CONTENTS, ALLOC, LOAD, DATA
  1 .rodata       00000438  3ffe8a00  3ffe8a00  00000ae0  2**4
                  CONTENTS, ALLOC, LOAD, READONLY, DATA
  2 .bss          00008a40  3ffe8e38  3ffe8e38  00000f18  2**4
                  ALLOC
  3 .text         0000661e  40100000  40100000  00000f18  2**2
                  CONTENTS, ALLOC, LOAD, READONLY, CODE
  4 .irom0.text   000258c8  40240000  40240000  00007540  2**4
Section info:
   Section|                   Description| Start (hex)|   End (hex)|Used space
      data|        Initialized Data (RAM)|    3FFE8000|    3FFE89F8|    2552
    rodata|           ReadOnly Data (RAM)|    3FFE8A00|    3FFE8E38|    1080
       bss|      Uninitialized Data (RAM)|    3FFE8E38|    3FFF1878|   35392
      text|            Cached Code (IRAM)|    40100000|    4010661E|   26142
irom0_text|           Uncached Code (SPI)|    40240000|    402658C8|  153800
Total Used RAM : 39024
Free RAM : 42896
Free IRam : 6644
Run objcopy, please wait...
objcopy done
Run gen_appbin.exe
No boot needed.
Generate eagle.flash.bin and eagle.irom0text.bin successully in folder firmware.
eagle.flash.bin-------->0x00000
eagle.irom0text.bin---->0x40000
Done
13:09:07 Build Finished (took 2s.493ms)
Thanks!
By j0hncc
#14858
Markus Gritsch wrote:How do you get the section info displayed (the lines between "LD build/app.out" and "Run objcopy, please wait...)"?
LOL beats me, I just double-clicked on the make all target :)
Does blinky2 work for you?
