By MikeyMoMo
#70912 I posted the salient bits. But if you want the rest, here it is. I have been on this project for a couple of months. So, yes, I have selected the WeMos D1 Mini. I have restarted the IDE. I have rebooted. This is a little test bed not the full project but it shows the deprecation error and crashes on me quite dependably.
Code: Select all#include <SD.h>
#include <ESP8266WebServer.h>
#include <SPI.h>
#include <IPAddress.h>
/* How IPAddress is defined in IPAddress.h */
//class IPAddress: public Printable
//private:
//  union {
//      uint8_t bytes[4];  // IPv4 address
//      uint32_t dword;
//  } _address;
//  // Access the raw byte array containing the address.  Because this returns a pointer
//  // to the internal structure rather than a copy of the address this function should only
//  // be used when you know that the usage of the returned uint8_t* will be transient and not
//  // stored.
//  uint8_t* raw_address()
//      return _address.bytes;
#define   MAX_CALLERS 300
typedef struct
  IPAddress iaddr;    // Little Endian
  IPAddress iaddrBE;  // Big Endian
  long      count;
} IPCallers;
IPCallers MyCallers[MAX_CALLERS];
IPCallers SDRead[MAX_CALLERS];
int WebRequests;
const char *STestFN = "test.txt";
const char *StuctFN = "Struct.txt";
String buffer;
IPAddress ip1( 10, 210,   0,   1);
IPAddress ip2(201,   2, 200,  22);
IPAddress ip3(123, 211, 135, 003);
IPAddress ip4( 96,   4,   4,   4);
int iTemp;
bool SD_Valid = true;   // Until proven otherwise.
#define chipSelect D8
// Pin used for CS for the SD shield.
IPAddress ipTemp, ipTempBE;
uint32_t myLocalIP;
File myFile;
  //Open serial communications and wait for port to open:
  while (!Serial) {
  Serial.print("\nInitializing SD card...");
  if (!SD.begin(D8)) {
    Serial.println("initialization failed!");
    return;
  Serial.println("initialization done.");
  //Initialize fields
  MyCallers[0].iaddr = ip1; MyCallers[1].iaddr = ip2;
  MyCallers[2].iaddr = ip3; MyCallers[3].iaddr = ip4;
  MyCallers[0].count = 10;  MyCallers[1].count = 9;
  MyCallers[2].count =  8;  MyCallers[3].count = 7;
  WebRequests = 4;
  for (iTemp = 0; iTemp < WebRequests; iTemp++) {
    MyCallers[iTemp].iaddrBE[0] = MyCallers[iTemp].iaddr[3];
    MyCallers[iTemp].iaddrBE[1] = MyCallers[iTemp].iaddr[2];
    MyCallers[iTemp].iaddrBE[2] = MyCallers[iTemp].iaddr[1];
    MyCallers[iTemp].iaddrBE[3] = MyCallers[iTemp].iaddr[0];
  PrintOrigStruct();
  Serial.println("By Count Ascending");
  SortCtA();
  PrintOrigStruct();
  Serial.println("By Count Descending");
  SortCtD();
  PrintOrigStruct();
  Serial.println("By IP Ascending");
  SortIPA();
  PrintOrigStruct();
  Serial.println("By IP Descending");
  SortIPD();
  PrintOrigStruct();
  Serial.println("Checking if file exists and removing if so.");
  if (SD.exists(STestFN))
    Serial.println("File exists, removing it now."); yield();
    SD.remove("test.txt");
  //Open the file. Note that only one file can be open at a time,
  //so you have to close this one before opening another.
  myFile = SD.open(STestFN, FILE_WRITE);
  //If the file opened okay, write to it:
  if (myFile) {
    Serial.print("Writing to test.txt...");
    myFile.println("testing 1, 2, 3.");
    //close the file
    myFile.close();
    Serial.println("done.");
  } else {
    //if the file didn't open, print an error
    Serial.println("error opening test.txt");
  //Now open the file for reading:
  myFile = SD.open(STestFN);
  if (myFile) {
    Serial.println("Reading test.txt:");
    //Read from the file until there's nothing else in it
    while (myFile.available()) {
      Serial.print(">"); Serial.print(myFile.readStringUntil('\n'));
//    iTemp = myFile.read());
    //Close the file
    myFile.close();
  } else {
    //If the file didn't open, print an error
  WriteIP(); ReadIP();
void WriteIP() {
  Serial.println("Testing if file exists."); yield();
  if (SD.exists("Struct.txt"));
    SD.remove("Struct.txt");
  Serial.println("Opening file now."); yield();
  File dataFile = SD.open(StuctFN, FILE_WRITE);
  if (dataFile) {  // Only try to write it if it opened successfully.
    Serial.println("Writing file data 1.");
    dataFile.println(WebRequests);
//      myLocalIP = (uint32_t) MyCallers[iTemp].iaddr;
      Serial.print("Numeric version of MyCallers[itemp].iaddr = "); Serial.println(myLocalIP);
//      dataFile.println(myLocalIP);
      dataFile.println((uint32_t) MyCallers[iTemp].iaddr);
      dataFile.println(MyCallers[iTemp].count);
    dataFile.close(); yield();
  } else {  // or if datafile did not open...
    Serial.print("Error opening "); Serial.println(STestFN); return;
  }  // if (datafile)}
void ReadIP() {
  int linesToRead;
  int linesRead = 0;
  long ct;
  myFile = SD.open(StuctFN);
  if (myFile) {
    Serial.println("Reading Struct.txt:");
//    while (myFile.available()) Serial.write(myFile.read());
    if (myFile.available()) {
      buffer = myFile.readStringUntil('\n');
      if (isValidNumber(buffer)) linesToRead = buffer.toInt();
      Serial.print("Converted count: "); Serial.println(linesToRead);
    //Read first IP as UL
      Serial.print("Line read: '");Serial.print(buffer); Serial.println("'"); yield();
      if (isValidNumber(buffer)) {
        myLocalIP = buffer.toInt();
        SDRead[linesRead].iaddr = (uint32_t)myLocalIP;
    //Read first count as int
        ct = buffer.toInt();
        SDRead[linesRead].count = ct;
      SDRead[linesRead].iaddrBE[0] = SDRead[linesRead].iaddr[3];
      SDRead[linesRead].iaddrBE[1] = SDRead[linesRead].iaddr[2];
      SDRead[linesRead].iaddrBE[2] = SDRead[linesRead].iaddr[1];
      SDRead[linesRead].iaddrBE[3] = SDRead[linesRead].iaddr[0];
      linesRead++;
    //Close the file
    myFile.close();
  } else {
  PrintReadStruct();
void PrintOrigStruct() {
    Serial.print(iTemp); Serial.print(">");
    Serial.print(MyCallers[iTemp].iaddr); Serial.print("\t- ");
    Serial.print(MyCallers[iTemp].iaddrBE); Serial.print("\t ts:");
    Serial.print(MyCallers[iTemp].iaddrBE.toString());
    Serial.print("\t("); Serial.print(MyCallers[iTemp].count);
    Serial.println(" times.)"); yield();
void PrintReadStruct() {
    Serial.print(SDRead[iTemp].iaddr); Serial.print("\t- ");
    Serial.print(SDRead[iTemp].iaddrBE); Serial.print("\t ts:");
    Serial.print(SDRead[iTemp].iaddrBE.toString());
    Serial.print("\t("); Serial.print(SDRead[iTemp].count);
void SortCtD() {
  IPAddress ipTemp;
  long ctTemp;
  for (iTemp = 0; iTemp < (WebRequests - 1); iTemp++) {
    for (int iSort = 0; iSort < WebRequests - iTemp - 1; iSort++) {
      if (MyCallers[iSort].count < MyCallers[iSort + 1].count) {
        ipTemp   = MyCallers[iSort].iaddr;
        ipTempBE = MyCallers[iSort].iaddrBE;
        ctTemp   = MyCallers[iSort].count;
        MyCallers[iSort].iaddr   = MyCallers[iSort + 1].iaddr;
        MyCallers[iSort].iaddrBE = MyCallers[iSort + 1].iaddrBE;
        MyCallers[iSort].count   = MyCallers[iSort + 1].count;
        MyCallers[iSort + 1].iaddr   = ipTemp;
        MyCallers[iSort + 1].iaddrBE = ipTempBE;
        MyCallers[iSort + 1].count   = ctTemp;
        yield();
void SortCtA() {
  IPAddress ipTemp;
  long ctTemp;
      if (MyCallers[iSort].count > MyCallers[iSort + 1].count) {
        yield();
void SortIPA() {
  IPAddress ipTemp;
  long ctTemp;
      if (MyCallers[iSort].iaddrBE > MyCallers[iSort + 1].iaddrBE) {
        yield();
void SortIPD() {
  IPAddress ipTemp;
  long ctTemp;
      if (MyCallers[iSort].iaddrBE < MyCallers[iSort + 1].iaddrBE) {
        yield();
boolean isValidNumber(String str){
   for(byte i = 0; i < str.length(); i++)
    if(isDigit(str.charAt(i))) return true;
   return false;
void loop() { }
By QuickFix
#70936 I'm not entirely sure what your code is supposed to do, but it's fairly easy for me to just compile and flash it.
So I took a Wemos D1 from the shelf, put it on a doubler-board with an SD-shield (inserted a 2GB microSD-card) at its side.
This is what my compiler is saying (don't mind the warnings, that's because I'm using the Git-master of the ESP8266 Arduino-core):
Code: Select allWARNING: library SPI claims to run on (esp8266) architecture(s) and may be incompatible with your current board which runs on (Arduino) architecture(s).
WARNING: library ESP8266WebServer claims to run on (esp8266) architecture(s) and may be incompatible with your current board which runs on (Arduino) architecture(s).
WARNING: library ESP8266WiFi claims to run on (esp8266) architecture(s) and may be incompatible with your current board which runs on (Arduino) architecture(s).
Archiving built core (caching) in: C:\Users\QUICKF~1\AppData\Local\Temp\arduino_cache_575934\core\core_esp8266com_Arduino_d1_mini_CpuFrequency_80,UploadSpeed_921600,FlashSize_4M3M_21655eb80f1d4fdd8e4dada24d8451b9.a
Sketch uses 256177 bytes (24%) of program storage space. Maximum is 1044464 bytes.
Global variables use 46688 bytes (56%) of dynamic memory, leaving 35232 bytes for local variables. Maximum is 81920 bytes.
Uploading 260320 bytes from C:\Users\QUICKF~1\AppData\Local\Temp\arduino_build_266395/sketch_oct17a.ino.bin to flash at 0x00000000
................................................................................ [ 31% ]
................................................................................ [ 62% ]
................................................................................ [ 94% ]
...............        [ 100% ]
After a succesful flash, the code runs and this is what my terminal says:
Code: Select allInitializing SD card...initialization done.
0>10.210.0.1   - 1.0.210.10    ts:1.0.210.10   (10 times.)
1>201.2.200.22   - 22.200.2.201    ts:22.200.2.201   (9 times.)
2>123.211.135.3   - 3.135.211.123    ts:3.135.211.123   (8 times.)
3>96.4.4.4   - 4.4.4.96    ts:4.4.4.96   (7 times.)
By Count Ascending
0>96.4.4.4   - 4.4.4.96    ts:4.4.4.96   (7 times.)
1>123.211.135.3   - 3.135.211.123    ts:3.135.211.123   (8 times.)
2>201.2.200.22   - 22.200.2.201    ts:22.200.2.201   (9 times.)
3>10.210.0.1   - 1.0.210.10    ts:1.0.210.10   (10 times.)
By Count Descending
By IP Ascending
1>96.4.4.4   - 4.4.4.96    ts:4.4.4.96   (7 times.)
3>201.2.200.22   - 22.200.2.201    ts:22.200.2.201   (9 times.)
By IP Descending
0>201.2.200.22   - 22.200.2.201    ts:22.200.2.201   (9 times.)
2>96.4.4.4   - 4.4.4.96    ts:4.4.4.96   (7 times.)
Writing to test.txt...done.
Reading test.txt:
>testing 1, 2, 3.
Opening file now.
Numeric version of MyCallers[itemp].iaddr = 0
Reading Struct.txt:
Converted count: 4
Line read: '382206665
Line read: '9
Line read: '59233147
Line read: '8
Line read: '67372128
Line read: '7
Line read: '16830986
Line read: '10
To me, it looks like it's compiling and running fine. :?
