- Sun Nov 09, 2014 6:19 am
#2363
I had a quick look at their AT code... Well,
fixing it is a far more difficult task than rewriting from scratch. It's even hard to use it as a reference. That's why I've started writing alternative firmware without any hesitation - I would spend way more time struggling with their bugs. And a clean and hackable codebase available to everyone looks like a way better solution.
Okay, here goes another update with more awesome commands. Binaries are updated as well. The firmware's now officially called 'Frankenstein', since it's hacked togather of different bits and pieces that somehow, surprisingly work. I've made some more verbose help messages as well.
Code: Select allFrankenstein ESP8266 Firmware
Powered by Antares 0.2-rc1, Insane Mushroom
(c) Andrew 'Necromant' Andrianov 2014 <andrew@ncrmnt.org>
This is free software (where possible), published under the terms if GPLv2
Memory Layout:
data : 0x3ffe8000 ~ 0x3ffe8a90, len: 2704
rodata: 0x3ffe8a90 ~ 0x3ffe9f38, len: 5288
bss : 0x3ffe9f38 ~ 0x3fff1378, len: 29760
heap : 0x3fff1378 ~ 0x3fffc000, len: 44168
=== Press enter to activate this console ===
blackblade > help
help - Show this message
apconfig - Setup Access Point.
apconfig name OPEN/WEP/WPA_PSK/WPA2_PSK/WPA_WPA2_PSK [password]
iwconnect - Join a network/Display connection status.
iwconnect ssid password
iwmode - Get/set wireless mode. Available modes: NONE, STA, AP, APSTA
iwmode STA
iwscan - Scan for available stations
ifconfig - Show/setup network interfaces
ifconfig [iface] [ipaddr] [netmask] [gateway]
ifconfig sta0 192.168.0.1 255.255.255.0 192.168.0.8
reset - Soft-reboot the device
meminfo - Display memory information
version - Display version information and copyright
blackblade >
Apart from rebooting, meminfo and version you can now display/set IP address information, connect to wireless stations and set up access point parameters.
It looks like SDK blobs code store parameters somewhere in flash and bad AP settings can cause exception when parameters are loaded and infinite reboots. For that not to happen Frankenstein now boots with wireless offline. (For now).
Quick receipe. Connect to an AP:
Code: Select allblackblade > iwmode STA
Wireless mode change: NONE -> STA
blackblade > iwconnect frostgate somepassword
blackblade > ifconfig sta0
sta0: WiFi Client Interface
inet addr:192.168.1.131 Mask:255.255.255.0 Gateway:192.168.1.2
blackblade >
At this point you may ping your station from any device on the network.
TODO:
Questions to be answered
Any way to disable built-in DHCP client and set IP manually
Any way to supply a hostname along with DHCP request
Where do AP parameters get stored in flash? How?
Anyway, network support is on the way. ping already somewhat works, the rest is just asking to be done.
