tnx!
SDM Energy Meter: https://github.com/reaper7/SDM_Energy_Meter
MLEDScroll (TM1640 led matrix): https://github.com/reaper7/MLEDScroll
Explore... Chat... Share...
alonewolfx2 wrote:It looks very good. Thank you again. I haven't one question. Is codecomplete feature working? (Like java in eclipse)
17:00:22 **** Build of configuration Default for project esphttpd ****
mingw32-make.exe -f C:/Espressif/examples/esphttpd/Makefile all
CC user/httpd.c
CC user/heatshrink_decoder.c
CC user/cgiwifi.c
CC user/espfs.c
CC user/base64.c
user/base64.c: In function 'base64_decode':
user/base64.c:54:3: error: array subscript has type 'char' [-Werror=char-subscripts]
if(isspace(in[ii])) continue;
cc1.exe: all warnings being treated as errors
mingw32-make.exe: *** [build/user/base64.o] Error 1
C:/Espressif/examples/esphttpd/Makefile:162: recipe for target 'build/user/base64.o' failed
