CARPP wrote:Did anyone fix the problem that the esp8266 just prints a lot of exception on the console if the program was compiled and flashed with the SDK >= 2.0? My controller doesn't do what it is supposed to do it just prints a lot of fatal exceptions. Does anyone know how to fix this?
oezcanacar wrote:Hi,
that did not work for me. For the hello world sample I see a lot of garbage on the terminal. If I change the baud rate to 78600, this is seen:Code: Select allchksum 0xcc
load 0x3ffe8380, len 332, room 4
tail 8
chksum 0xdd
csum 0xdd
rf_cal[0] !=0x05,is 0xFF
load 0x40100000, len 27304, room 16
tail 8
chksum 0x0a
load 0x3ffe8000, len 884, room 0
tail 4
chksum 0xcc
tail 8
chksum 0xdd
csum 0xdd
tail 8
chksum 0x0a
tail 4
chksum 0xcc
tail 8
chksum 0xdd
csum 0xdd
tail 8
chksum 0x0a
tail 4
chksum 0xcc
tail 8
chksum 0xdd
csum 0xdd
Any idea, how to eliminate this issue?
Thanks
Dear,
Have you solve your problem?
davydnorris wrote:That cal error is familiar - did you flash the esp_init_data_default.bin in the right place?
Same error, can you explain were is the right place? Older versions it works fine just typing "make flash"
Thanks
