By jcmvbkbc
#1148
mikelelere wrote:the solution was including the -mno-text-section-literals
Looks like assembler bug. It deals well with call8 to external symbols, but somehow fails for call0. I'll take a look.
By zarya
#1174
jcmvbkbc wrote:Looks like assembler bug. It deals well with call8 to external symbols, but somehow fails for call0. I'll take a look.
i am not sure what in the code triggers this, the at example is not affected.
By jcmvbkbc
#1176
If you'd like to find out for sure please share at least the full compiler command line.
By Squonk
#1178 I have the issue when compiling dumbcraft's "dumbutils.c" from https://github.com/cnlohr/dumbcraft8266
Here is my full (not edited) command line:
Code: Select allCC user/dumbutils.c
/home/mstempin/devel/crosstool-NG/builds/xtensa-lx106-elf/bin/xtensa-lx106-elf-gcc -Iinclude -Idriver -Iuser -Idriver/include -Iuser/include -I/home/mstempin/devel/ESP8266_SDK/lx106_linux/lx106/xtensa-elf/include -I"/home/mstempin/devel/espressif_iot_esp8266_development_kit_20140929/ESP8266 SDK AT FlashDownloadTool/esp_iot_sdk_v0.9.2"/include -I"/home/mstempin/devel/espressif_iot_esp8266_development_kit_20140929/ESP8266 SDK AT FlashDownloadTool/esp_iot_sdk_v0.9.2"/include/json -Os -g -O2 -Wpointer-arith -Wundef -Werror -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals  -D__ets__ -DICACHE_FLASH  -c user/dumbutils.c -o build/user/dumbutils.o
/tmp/ccA64CS7.s: Assembler messages:
/tmp/ccA64CS7.s:30: Error: literal pool location required for text-section-literals; specify with .literal_position
make: *** [build/user/dumbutils.o] Erreur 1
Here is the preprocessed ("-E") corresponding file: it is rather short:
dumbutils.c
This is using your latest crosstoll-NG from github.
Hope it helps!
