Error: jlink_tap_execute failed, result 5 (unknown)
Error: failed to scan tap instruction
Error: Failed to read DOSR. Not Xtensa OCD?
Polling target esp8266.cpu failed, trying to reexamine
Error: Failed to examine target.
Examination failed, GDB will be halted. Polling again in 100ms
Warn : Warning: Target not halted, breakpoint/watchpoint state may be unpredictable.
This is the general failure on startup.
ril3ys-MBP:openocd ril3y$ openocd -f tcl/interface/jlink.cfg -f ./tcl/target/esp8266.cfg
Open On-Chip Debugger 0.9.0-rc1-dev-00457-g6a7dd37-dirty (2015-10-14-16:07)
Licensed under GNU GPL v2
For bug reports, read
http://openocd.org/doc/doxygen/bugs.html
srst_only separate srst_gates_jtag srst_open_drain connect_deassert_srst
adapter speed: 1000 kHz
stop_wdt
Info : J-Link ARM V8 compiled Feb 8 2012 14:30:39
Info : J-Link caps 0xb9ff7bbf
Info : J-Link hw version 80000
Info : J-Link hw type J-Link
Info : J-Link max mem block 9336
Info : J-Link configuration
Info : USB-Address: 0x0
Info : Kickstart power on JTAG-pin 19: 0xffffffff
Info : Vref = 0.977 TCK = 1 TDI = 0 TDO = 0 TMS = 0 SRST = 1 TRST = 1
Error: Vref too low. Check Target Power
Info : J-Link JTAG Interface ready
Info : clock speed 1000 kHz
Error: JTAG scan chain interrogation failed: all zeroes
Error: Check JTAG interface, timings, target power, etc.
Error: Trying to use configured scan chain anyway...
Error: esp8266.cpu: IR capture error; saw 0x00 not 0x01
Warn : Bypassing JTAG setup events due to errors
^C
If anyone has some suggestions I am very much interested. Oh and btw I submitted a patch to get openocd build on OSX under an Issue on the main github.
Thanks!
ril3y
