Nice work! I admit I let this slide after getting involved in esp-open-rtos. Can't wait to try out the updates.
Angus
Explore... Chat... Share...
(gdb) mon reset halt
TAP esp8266.cpu does not have IDCODE
xtensa_poll: DOSR has set InOCDMode without the Exception flag. Unexpected. DOSR=0x04
esp8266.cpu: target state: halted
halted: PC: 0x4000118c
debug cause: 0x20
xtensa_deassert_reset: 'reset halt' is not supported for Xtensa. Have halted some time after resetting (not the same thing!)
(gdb) load app.out
Loading section .data, size 0xa4c lma 0x3ffe8000
Loading section .rodata, size 0xda8 lma 0x3ffe8a50
Loading section .text, size 0x5bfe lma 0x40100000
Loading section .irom0.text, size 0x2137c lma 0x40240000
Start address 0x40100004, load size 165742
Transfer rate: 27 KB/sec, 12749 bytes/write.
(gdb) set $pc=0x40100004
(gdb) info frame
Stack level 0, frame at 0xf00d020c:
pc = 0x4000118c; saved pc 0x40260fbc
called by frame at 0xf00d020c
Arglist at 0xf00d020c, args:
Locals at 0xf00d020c, Previous frame's sp is 0xf00d020c
(gdb) stepi
0x40005668 in ?? ()
(gdb) stepi
0x4000566b in ?? ()
(gdb) stepi
0x4000566d in ?? ()
(gdb) stepi
0x4000118f in ?? ()
(gdb) stepi
0x40001189 in ?? ()
(gdb) stepi
xtensa_step: Timed out waiting for target to finish stepping.
[Remote target] #1 stopped.
0x4000118c in ?? ()
(gdb)
Open On-Chip Debugger 0.9.0 (2016-08-09-00:01)
Licensed under GNU GPL v2
For bug reports, read
http://openocd.org/doc/doxygen/bugs.html
trst_and_srst separate srst_gates_jtag trst_push_pull srst_open_drain connect_deassert_srst
adapter speed: 1000 kHz
TapName Enabled IdCode Expected IrLen IrCap IrMask
0 esp8266.cpu Y 0x00000000 0x00000000 5 0x01 0x1f
stop_wdt
Info : clock speed 1000 kHz
Error: JTAG scan chain interrogation failed: all zeroes
Error: Check JTAG interface, timings, target power, etc.
Error: Trying to use configured scan chain anyway...
Error: esp8266.cpu: IR capture error; saw 0x00 not 0x01
set _CHIPNAME esp8266
interface ftdi
ftdi_vid_pid 0x0403 0x6010
ftdi_serial "ATAF31C"
ftdi_layout_init 0x0000 0x003b
ftdi_layout_signal nTRST -data 0x0010 -noe 0x0010
ftdi_layout_signal nSRST -noe 0x0020
ftdi_channel 0
transport select jtag
reset_config srst_only
adapter_khz 1000
jtag newtap $_CHIPNAME cpu -irlen 5 -ircapture 0x1 -irmask 0x1f
scan_chain
set _TARGETNAME $_CHIPNAME.cpu
target create $_TARGETNAME xtensa -endian little -chain-position $_TARGETNAME
# esp8266 seems to have a quirk where the JTAG hardware doesn't work
# at all for ~20ms after RST is released. We do a custom reset to
# avoid JTAG layer errors
proc init_reset {mode} {
# assert both resets (SRST/TRST not a clear division on esp8266 anyhow)
jtag_reset 1 1
sleep 30
jtag_reset 0 0
# wait for debug port to wake up
sleep 30
# validate scanchain
jtag arp_init
# Disable system watchdog when halted to avoid unexpected resets
$_TARGETNAME configure -event halted {
stop_wdt
proc stop_wdt { } {
mww 0x60000900 0
