I am not super aquinted with makefile's but what I am trying to do is create the user1.bin and user2.bin files and in this case named blinky-0x1000.bin and blinky 0x81000.bin. This requires compiling Blinky.c then fashing it with the Esptool then clearing the Blinky files then changing the LDFlag to eagle.app.v6.new.1024.app2 then repeating to a different address. I've burned about 8 hours stright trying to bend this make file on regenerating the two files and flashing them to the chip. Any makefile Guru's out there? Thank you so much!!
CC = xtensa-lx106-elf-gcc
CFLAGS = -I. -DICACHE_FLASH -mlongcalls
LDLIBS = -nostdlib -Wl,--start-group -lmain -lnet80211 -lwpa -llwip -lpp -lphy -lc -Wl,--end-group -lgcc
LDFLAGS = -Teagle.app.v6.new.1024.app1.ld
INCLUDES = -Iinclude -I../driver_lib/include
ifeq ($(OS),Darwin)
$(info OS is $(OS))
CC=g++
LDFLAGS=-lm -framework OpenCL
CFLAGS+=-O3
endif
blinky-0x00000.bin: blinky
echo a
echo $(LDFLAGS)
esptool.py elf2image $^
fotablinky-0x81000.bin: LDFLAGS=-Teagle.app.v6.new.1024.app2.ld
fotablinky-0x81000.bin: blinky
echo b
echo $(LDFLAGS)
rm -f blinky.o
esptool.py elf2image --version 2 blinky
esptool.py write_flash --flash_size 32m-c1 0x81000 blinky-0x81000.bin
fotablinky-0x01000.bin: blinky
echo c
echo $(LDFLAGS)
esptool.py write_flash --flash_size 32m-c1 0 boot_v1.7.bin 0x1000 blinky-0x01000.bin 0x7e000 blank.bin 0xFE000 blank.bin 0x3FC000 esp_init_data_default.bin
blinky: blinky.o
blinky.o: blinky.c
dhonewire: dhonewire.o
dhonewire.o: dhonewire.c
fresh: blinky-0x00000.bin
echo d
echo %LDFLAGS%
#kill $(ps aux | grep '[S]CREEN' | awk '{print $2}')
esptool.py write_flash 0 blinky-0x00000.bin 0x10000 blinky-0x10000.bin 0x7e000 blank.bin 0x3fc000 esp_init_data_default.bin 0x3fe000 blank.bin 0x60000 index.html 0x80000 config.html
#screen /dev/ttyUSB0 74880
screen /dev/ttyUSB0 115200
flash: blinky-0x00000.bin
echo e
echo %LDFLAGS%
esptool.py write_flash 0 blinky-0x00000.bin 0x10000 blinky-0x10000.bin 0x60000 index.html 0x80000 config.html
quick: blinky-0x00000.bin
echo f
echo $(LDFLAGS)
build: blinky-0x00000.bin
echo g
echo $(LDFLAGS)
ota: fotablinky-0x01000.bin fotablinky-0x81000.bin
#export -p
echo h
echo $(LDFLAGS)
#esptool.py write_flash --flash_size 32m-c1 0x81000 blinky-0x81000.bin
clean:
echo i
rm -f blinky blinky.o blinky-0x00000.bin blinky-0x10000.bin blinky-0x81000.bin blinky-0x01000.bin
#echo 'osboxes.org' | sudo -S chmod 777 /dev/ttyUSB0 #No longer needed, osboxes added to dialout group with usermod
