By riker1
#72436 Hi
I am having 2 setups to get the ESP up and running.
1. UART USB Cable straigt to ESP01
2. Arduino Uno and ESP01 attached.
I am confused - found different information about wiring them up.
- RX -> RX vs. RX-> to TX, vice versa.
Different setups with resistors and capacitators, some without any ...
i tried all....
now I have the problem.
not getting an AT ok!
and while uploading - diffent technics used: reset (rst -> gnd) and flash (gpio -> gnd)- used.
I get errors:
warning: espcomm_send_command: wrong direction/command: 0x00 0x08, expected 0x01 0x08
maybe anyone can solve my confusion.
Thanks T
Sketch is very easy and working on an NodeMCU .
I tired upload via Arduino IDE with Generic ESP6288 Board.
Different bauds as well.
Thanks for helping !!
resetting board
trying to connect
espcomm_send_command: sending command header
espcomm_send_command: sending command payload
serialport_receive_C0: 00 instead of C0
trying to connect
espcomm_send_command: receiving 36 bytes of data
trying to connect
resetting board
trying to connect
serialport_receive_C0: 08 instead of C0
trying to connect
trying to connect
By Laurent31
#76166 Hi,
I have got the same error (00 instead of C0). I Just cannot understand what happens
Have you fixed the issue ?
Please advise
Laurent
By QuickFix
#76246 If new, buy a development board first. :idea:
See my signature, it's there for a reason (since so many new people fail trying to get the ESP-01 to work).
An ESP-01 costs $1.50, a development board twice that amount (~$3), but you'll get an instantly working setup.
Don't try to make things harder for yourself than necessary; it will only demotivate you. :o
