By Necromant
#3307 Is there a proper way to make an atomic section to be 100% sure no interrupt kicks in during it?
is there something like
Code: Select allATOMIC_BLOCK(ATOMIC_RESTORESTATE)
we had on avr or spin_lock_irqsave/spin_unlock_irqrestore calls in linux kernel?
By jcmvbkbc
#3317
Necromant wrote:Is there a proper way to make an atomic section to be 100% sure no interrupt kicks in during it?
Code: Select allstatic inline unsigned long arch_local_irq_save(void)
        unsigned long flags;
        asm volatile("rsil %0, 1"
                     : "=a" (flags) :: "memory");
        return flags;
static inline void arch_local_irq_restore(unsigned long flags)
        asm volatile("wsr %0, ps; rsync"
                     :: "a" (flags) : "memory");
1 in the rsil instruction is the maximal level of normal interrupts for our lx106 core.
linux mainline has support for xtensa, so you can look up there.
By Nurgak
#37056 I'm in a situation where I think atomic operations are required:
Code: Select allstatic volatile uint16_t counter = 0;
void interruptRoutine()
  counter++;
void setup(void)
  attachInterrupt(5, interruptRoutine, FALLING);
void loop(void)
  static uint16_t counterTemp = 0;
  static uint16_t callCounter = 0;
  if(callCounter++ == 10)
    callCounter = 0;
    // These two lines should probably be atomic
    powerCounterTemp = powerCounter;
    powerCounter = 0;
    // Do something with powerCounterTemp...
There's no way to know when the interrupt routine is called, it could certainly be between powerCounterTemp = powerCounter; and powerCounter = 0;, which would make some counts miss and that cannot be allowed. How would one go and make sure the 2 lines on the ESP? I really like the ATOMIC_BLOCK way of doing it, but is it available on the ESP?
