Code size of my application is increasing and currently, I am not interested in losing 256K for OTA.
I am using the ESP_IOT_SDK_v1.5.0_15_11_27.
I am using the Eclipse build setting from this link on Windows- http://www.esp8266.com/viewtopic.php?t=820
My Liker file unmodified is :
MEMORY
dport0_0_seg : org = 0x3FF00000, len = 0x10
dram0_0_seg : org = 0x3FFE8000, len = 0x14000
iram1_0_seg : org = 0x40100000, len = 0x8000
irom0_0_seg : org = 0x40240000, len = 0x3C000
14:30:06 **** Build of configuration Release for project Vyuha ****
mingw32-make -f C:/Users/Ravi/workspace/Vyuha/Makefile all
CC driver/uart.c
CC user/usergtdp.c
CC user/user_json.c
CC user/user_main.c
CC user/gtdplite.c
CC mqtt/proto.c
CC mqtt/utils.c
CC mqtt/queue.c
CC mqtt/mqtt_msg.c
CC mqtt/ringbuf.c
CC mqtt/mqtt.c
CC modules/wifi.c
CC modules/config.c
AR build/app_app.a
LD build/app.out
c:/espressif/xtensa-lx106-elf/bin/../lib/gcc/xtensa-lx106-elf/5.1.0/../../../../xtensa-lx106-elf/bin/ld.exe: build/app.out section `.text' will not fit in region `iram1_0_seg'
collect2.exe: error: ld returned 1 exit status
C:/Users/Ravi/workspace/Vyuha/Makefile:189: recipe for target 'build/app.out' failed
mingw32-make: *** [build/app.out] Error 1I pulled out some code and it compiles, with < 700 bytes of iRAM, What needs to be done?
17:49:36 **** Build of configuration Release for project Vyuha ****
CC user/user_main.c
CC user/gtdplite.c
CC mqtt/proto.c
CC mqtt/utils.c
CC mqtt/queue.c
CC mqtt/mqtt_msg.c
CC mqtt/ringbuf.c
CC mqtt/mqtt.c
CC modules/wifi.c
CC modules/config.c
AR build/app_app.a
LD build/app.out
Section info:
build/app.out: file format elf32-xtensa-le
Sections:
Idx Name Size VMA LMA File off Algn
0 .data 00000838 3ffe8000 3ffe8000 000000e0 2**4
CONTENTS, ALLOC, LOAD, DATA
1 .rodata 000019c4 3ffe8840 3ffe8840 00000920 2**4
CONTENTS, ALLOC, LOAD, READONLY, DATA
2 .bss 00006638 3ffea208 3ffea208 000022e8 2**4
ALLOC
3 .text 00007d46 40100000 40100000 000022e4 2**2
CONTENTS, ALLOC, LOAD, READONLY, CODE
4 .irom0.text 0003b904 40240000 40240000 0000a030 2**4
Section| Description| Start (hex)| End (hex)|Used space
data| Initialized Data (RAM)| 3FFE8000| 3FFE8838| 2104
rodata| ReadOnly Data (RAM)| 3FFE8840| 3FFEA204| 6596
bss| Uninitialized Data (RAM)| 3FFEA208| 3FFF0840| 26168
text| Uncached Code (IRAM)| 40100000| 40107D46| 32070
irom0_text| Cached Code (SPI)| 40240000| 4027B904| 243972
Entry Point : 40100004 call_user_start()
Total Used RAM : 34868
Free RAM : 47052
Free IRam : 698 or 17082 if 48k IRam
Generate 0x00000.bin and 0x40000.bin successully in folder firmware.
0x00000.bin-------->0x00000
0x40000.bin-------->0x40000
Done
How to use all the flash for application? I don't want OTA.
Regards,
Ravi
