ESP-12S
ESP-12E
I also confirmed it on two NodeMCU boards with each module
I started another post showing the test code I'm using a couple days ago, viewtopic.php?f=6&t=17975
Explore... Chat... Share...
craigfoo wrote:There are actually two separate test setups shown ...
If it were a bypass capacitor issue, you would assume that the ESP-12E pulse would be the bad one because the ESP-12S is supposed to have more internal capacitors on the power lines.
