CP2102:
ESP 12-F and auto programming circuit:
What works:
1: The ESP-module has a stable 3.3V power supply able to supply sufficient current
2: Using a serial terminal I can write to the RX pin on the ESP-module and read that it arrives using a logic analyzer (i.e the CP2102 works)
3: Boot message on serial terminal (with no handshake) when I press the reset button is:
load 0x40100000, len 25408, room 16
tail 0
chksum 0xef
load 0x00000000, len 0, room 8
tail 0
chksum 0xef
load 0x00000000, len 0, room 0
tail 0
chksum 0xef
csum 0xef
csum err
ets_main.c
What I have tried so far:
1: Added this URL http://arduino.esp8266.com/versions/2.4.0/package_esp8266com_index.json in the window for Additional Board Manager URLs in the Preferences in Arduino IDE v1.8.5.
2: Chosen NodeMCU 1.0 (ESP 12-E Module) under Tools -> Boards, as the schematic and auto reset circuit should be the same. I am unsure if the difference between ESP 12-E and ESP 12-F makes a difference though
3:Chosen the correct COM-port
4: Tried to upload ESP8266 -> Blink example but gotten this error message:
warning: espcomm_sync failed
error: espcomm_open failed
error: espcomm_upload_mem failed
5: Installed Visual Studio with platformIO package, also chosen the same board (NodeMCU 1.0 (ESP 12-E Module))
6: Written a short Arduino sketch:
#include <Arduino.h>
Serial.begin(9600);
delay(1000);
Serial.println("Hello World!");
7: Built and uploaded, but still gotten the same error message:
8: I have tried to upload the sketches from both point 4 and 7 after holding in the reset button then tying GPIO0 to ground manually, releasing reset button and getting boot mode: (1 6), but still gotten the same error message.
9: When uploading the Arduino sketches without manually resetting, using a logic analyzer, I see that the RTS line goes high, and should pull GPIO0 low, but GPIO0 continues to output the 26 MHz clock signal. Is this expected behaviour?
I would really appreciate some input and/or help, as I have been googling potential solutions for days now.
Thanks
-Martin
