I am trying to figure out something but i have found nothing relating to it so i hope maybe someone here will know.
I have a wifi based gestural system that consists of 3 wifi stations and an access point. I have been doing this with 3 rn-xv trancievers attached to arduino fios. connecting to a standard wireless router over wifi. it is an open source project i am preparing to release but the cost of the fios and the rn-xv's makes it prohibitively expensive (approximately $175 for 3 fios and 3 rn-xvs, not including batteries sensors, etc.) this is the project https://i.ytimg.com/vi/xOUFublvNUk/maxresdefault.jpg I decided to shift everything over to the esp8266's because they are more powerful and seem to be far more programmable and cut the cost of building a system down to a total cost of about $65 (in additon to using chinese accelrometers and raw atmega 328p IC's.
the way i use wifi is simply to use UDP to blast the firmata formatted serial data to the computer, running pure data , process it, then blast back LED control data to the in the body worn system. the total amount of data is about 200kb per unit. i use a flush timer to clear the buffer every 5ms at a 115200bps baud rate i am still hoping that i can discover (with your help) how to use the ESP-01's i have, to replicate this somehow. basically a data dump from the arduino over udp and then a dump from the computer back to the arduino as fast as the components can handle.
I also have an esp-12 that i want to use as the access point to replace the wireless router so the whole system can be used with raspberry pi's and worn. this piece is the last part of the puzzle. i "think" th access point should be pretty easy and the rpi's are all ready to go as well. any insight would allow me to have the project ready for a youth workshop i am preparing for in a couple of weeks where i hope to share the joy of programming with kids here in detroit. in exchange, i will be sure to post the updated project here as soon as it works.
![Smile :-)](./images/smilies/icon_e_smile.gif)
cheers!
