By piersfinlayson
#62453 I had one D1 mini (out of many) where one of the GPIO pins wasn't working properly. I resoldered the appropriate pad of the daughter module, and it started working. Quick and easy so may be worth a try.
By Marco Lazzarotto
#62508
yudxp wrote:
Marco Lazzarotto wrote:
gdsports wrote:Possible bad cable.
viewtopic.php?f=28&t=13452&hilit=bad+cable
I tried with another cable on another computer. I think that was dead before I received it.
have you try program it with another usb serial like FTDI?
Yes I did, I connected TX with RX and RX with TX without success (same error).
By Marco Lazzarotto
#62509
piersfinlayson wrote:I had one D1 mini (out of many) where one of the GPIO pins wasn't working properly. I resoldered the appropriate pad of the daughter module, and it started working. Quick and easy so may be worth a try.
You mean to solder the ESP8266 to the board?
