esp8266 otb-iot documentation - https://otb-iot.readthedocs.io/
esp8266 related blog - http://www.packom.net/
Explore... Chat... Share...
yudxp wrote:Marco Lazzarotto wrote:gdsports wrote:Possible bad cable.
viewtopic.php?f=28&t=13452&hilit=bad+cable
I tried with another cable on another computer. I think that was dead before I received it.
have you try program it with another usb serial like FTDI?
piersfinlayson wrote:I had one D1 mini (out of many) where one of the GPIO pins wasn't working properly. I resoldered the appropriate pad of the daughter module, and it started working. Quick and easy so may be worth a try.
