By Lawrence_jeff
#6407 Are you sure you are not pulling GPIO0 low and putting it in bootloader mode at start?
Also GPIO2 also needs to be high on bootup apparently, according to a comment here
https://scargill.wordpress.com/2015/01/ ... /#comments
"Don’t forget that GPIO2 and U0TXD should be kept high during power-up (they have internal pull-ups enabled). This also limits the use of GPIO2, we cannot apply a strong low level to it during start."
By martinayotte
#6410
JannikJung0 wrote:Okay, so I have two coices now:
Should I go with a 2N7000 (N-CH MOSFET) or a BS-208 (P-MOSFET) ?
Or do you have any other part suggestion ?
2N7000 should be good to drive your relay, except if it has a monster coil ... Do you know it consumption ?
For your prototyping, since you mentionned you don't have MOSFET in stock, simply do a darlington with 2 NPN transistors.
By JannikJung0
#6471
Lawrence_jeff wrote:Are you sure you are not pulling GPIO0 low and putting it in bootloader mode at start?
That's the case.. GPIO2 is pulled down to ground on bootup, that's why it isn't booting up.
So I will wait until the MOSFETs arrive, the relay needs less than 400mA, so it should be fine.
Thanks everybody for your help!
