Should I go with a 2N7000 (N-CH MOSFET) or a BS-208 (P-MOSFET) ?
Or do you have any other part suggestion ?
Explore... Chat... Share...
JannikJung0 wrote:Okay, so I have two coices now:
Lawrence_jeff wrote:Are you sure you are not pulling GPIO0 low and putting it in bootloader mode at start?
Also GPIO2 also needs to be high on bootup apparently, according to a comment here
https://scargill.wordpress.com/2015/01/ ... /#comments
"Don’t forget that GPIO2 and U0TXD should be kept high during power-up (they have internal pull-ups enabled). This also limits the use of GPIO2, we cannot apply a strong low level to it during start."
