Thanks for trying guys....
Harold Clements
ICQ: 621094716
Explore... Chat... Share...
alonewolfx2 wrote:you cant use arduino rx tx with atmega chip. if you remove atmega on board and try again propably it will workactually you can.
gerardwr wrote:If you have a standard AT firmware delivered on the board the "jibberish" should be followed by the prompt ( a ">"").should it be "ready" and not ">"?
haroldjclements wrote:OK, with a 10K resistor across RST and GPIO0 I get a fast flashing blue LEDthat's strange. if everything is ok, you should be able to something on your terminal now that the blue led flashed on power up.
