- Wed Jan 21, 2015 5:54 pm
#7909
Sorry it took so long but here is what I found:
The board boots up every time with 20141222 but I suspect it resets itself during use. I left it running for the last days loaded with some web server example from this forum(the one with the led pwm but with no led connected - just for testing because the webpage is supposed to remember the last led power level) and while I could access it every time sometimes it just displayed 0% even if i always left it at a random value just to test this.
I also run into another problem that was not here before. When i ping the esp i get a DUP!(duplicate response) message back.
I tried ping it with the web server unloaded and get the same.
I then flashed the latest 20150108 nodeMCU and the boot problems are back and I still get the DUP! stuff.
My conclusion is that:
1) Either I did something to the board (I did get pretty hot on some occasions) and it's now unreliable.
2) I'm doing something wrong when I flash it.
To eliminate the latter here's my flash process:
I flash it using the esptool.py from github using the
./esptool --port /dev/tty.usbserial write_flash 0x000000 nodemcu_20150108.bin
command on an OSX machine.
For now my plan is to find another way to flash it and try to rule this flashing gone bad theory out.
How are you flashing your boards?
Did it ever fail to flash? (mine did quite a few times and I had to retry and eventually it would work)
