- Thu Jan 29, 2015 10:26 pm
#8498
weswitt wrote:digikey has 2mm pitch headers (http://www.digikey.com/catalog/en/partg ... ries/20251) but I would like to know if the pins on these headers will fit the holes on the ESP-12 or do I need headers with thinner pins??
From the datasheet, those pins have a .5mm square section, that's .7mm diagonally. I don't have any measurement of the esp-12 holes, but I tried a .50mm wire, and it was loose so I guess those headers would be a tight fit. If anyone ends up buying some, it'd be nice to know for sure.
sej7278 wrote:the white adaptor boards [...] don't leave any pins to the left or right to add jumpers etc?
Correct. You can see a picture on Piotr's blog, and how he routed wires underneath the breakout board to reach the pins:
http://blog.3mdeb.com/sej7278 wrote:what are the resistors for?
Features:
+ 10K resistor between CHPD and VCC, to enable chip;
+ 10K resistor between GPIO2 and GND;
+ Reserved LDO place on the back of board;
+ GPIO15 to GND for normal flash boot mode;
+ only need power VCC GND for power up the module, and TX, RX for serial communication;
+ a capacitor?
http://www.electrodragon.com/product/esp8266-smd-adapter-board-wi07-12/sej7278 wrote:i've ordered some yellow boards [...] do they even fit breadboard?
Let's know when you know ;)
