By alonewolfx2
#12095 0.99$ but i am searching reliable seller.
EDIT: it seems the seller is reliable and price is good.
http://www.ebay.com/itm/5pcs-5V-1A-USB- ... 1608&rt=nc
By sej7278
#12101 does anyone have any preference for 18650 cells?
this looks like it has a nice 6000mAh for 99p: http://www.ebay.co.uk/itm/281626121177 (edit: terrible reviews, more like 1500mAh)
are there any with protections built-in, just seems if you're doubling the price by adding a charger/monitor circuit, you may as well pay £2 for a battery with pc internalised.
By Mikejstb
#12111 I've been using tiny Lipo batteries used for Syma quad coptors - 3.7 v 600 mah.
Using a similar little usb charger card as you show. It's stand-alone, JRT connectors on the battery, charger, & ESP. I take the battery off the ESP to charge as I'm not certain that it's ok to leave it connected while running.
I set the ESP up to send temp (ds18b20) and node.readvdd33() every 30 minutes and dsleep in between.
I was going to put a diode in line to drop the voltage down but as an experiment I didnt.
They've been running for 2 weeks now, voltage is still reporting as 4090 - looks like it's going to run for a LONG time before it needs recharging!
I'm going to look into the battery you suggest, I'm not sure which will be smallest or best.
By canibalimao
#12113
sej7278 wrote:does anyone have any preference for 18650 cells?
I don't know where did you find the reviews, but I don't need to read bad reviews about these batteries to know they are not as good as advertised :lol:
You can allways buy the kind of cheap batteries and then use a chager with battery protection (over charge and discharge) to avoid potential problems, but never expect they last as long as the advertise said...
