Though I'll be using multiple (parallel) vias in the VCC track.
Explore... Chat... Share...
faceplant wrote:Not a bad design, but the feed line looks like it's much longer than it needs to be. I would place the esp8266 and antenna first (close together) and then route the other stuff around it to keep the feed line short.
faceplant wrote:Also, it looks like you have ground plane on the bottom of the board under the antenna. I'm not an antenna expert, but I thought the board was supposed to be free from anything above and below.
