By AtomSoft
#10133 Hey guys im new here and this is NOT meant to be a ad or anything but more of a want to show you some boards i have available.
First is the ESP8266 Buddy. Its a simple breadboard friendly 01 helper. It allows you to connect your ESP8266 to a breadboard fast and clean.
The next one is my ESP8266 Flasher for 01 boards also.
You can find these on my tindie store. https://www.tindie.com/stores/AtomSoft/
Im also creating a LARGE PCB to allow for all versions Flashing without soldering! Will cost more but will be so awesome. If i can get some support for it that would rock! Also check out my site/blog... http://AtomSoftTech.com
By Tomega3
#11221 Hi, I have one of your esp buddy v2 flasher boards and it works great.
Here is what I did to flash new firmware on the ESP8266 ESP-01 wifi board that comes with an EspToy. (see http://rayshobby.net/esptoy/ )
I've been searching around the net for almost a month and combined bits and pieces of info that today actually worked.
I flashed the espressif AT firmware (ESP8266 SDK (esp_iot_sdk_v0.9.5_15_01_23) as found here:
http://bbs.espressif.com/viewtopic.php?f=5&t=154
download the zip file and unzip it.
see the documents\english folder for the AT command descriptions.
see the bin and bin\at folders for the files to be flashed, in the bin folder see the readme.txt file for what bin files are needed and what addresses are used for each bin file.
I remove the ESP-01 from the ESPToy and connect it to a helper board called esp buddy v2 flasher,
see https://www.tindie.com/products/AtomSoft/espbuddy-v2-flasher/
and a USB FTID 3.3v board found on ebay: 3.3V 5.5V FT232RL FTDI USB to TTL Serial Adapter Module
see http://www.ebay.com/itm/361071401255?_trksid=p2059210.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
I put the esp buddy v2 flasher switch in PROG position and press and release the rest button. The esp-01 is now ready to accept new firmware.
I use a esp8266 flash program called nodemcu flasher (see https://github.com/nodemcu/nodemcu-flasher connected to the USB port of my USB FTDI board.
There is some good info on how to use the nodemcu flasher here: see topic: esp8266 AT commands not recognized author MikeBolton
http://www.esp8266.com/viewtopic.php?f=6&t=1263&start=10#p8481
These are the bin files and addresses I used:
boot_v1.2.bin 0x00000
user1.512.new.bin 0x01000
blank.bin 0x3e000 & 0x7e000
When its done flashing, move the espbuddy v2 flasher switch back to NORMAL position and press and release the reset button.
The ESP-01 is now reflashed and its baudrate should be 115200.
You can test it by connecting a terminal editor to the USB FTDI board at 115200 and issue AT and AT+GMR to see what version of firmware is installed. (AT commands need to be sent with a carriage return and linefeed)
With an external 3.3v power supply connected to the ESP-01 vcc pin and its gnd shared with esp-01and my USB FTDI board and the 3.3v pin from my USB FTDI board NOT connected to the esp-01 vcc pin I was able to successfully try espressif 'cloud update' by following their instructions in the readme.txt file.
It is my hope that this may help other newbees like me to load the every changing firmware on this fantastic little wifi module.
