Explore... Chat... Share...
martinayotte wrote:Waste of time ... If an USB adaptor is needed, I would rather continue using Realtek or Ralink USB dongles.
(Espcially that throughput is about 100 times faster then what can be done over serial.)
Tito781227 wrote:i mean you can buy this chip with 3 dollars!,
QuickFix wrote:Tito781227 wrote:i mean you can buy this chip with 3 dollars!,
I think less than €2 for a USB-WiFi adapter is pretty cheap (and it's ready to use).
Or if you want a RealTek with external antenna: €2.24
